First attempt
  • Cougar33
    • Feb 2018
    • 9
    First attempt
    Hello everybody
    I am new in this field. so thought i would join and pick some peoples brains here.
    I have been designing boats for the past 20 years. mostly sailboats and a few airplanes. but as i got bored this year. I decided to try a field i knew nothing about, fast electrics. I did one from a set of plans a friend had when i was very young. and didnt go so well. So here i am with a new design
    I am working off a 3d drawing of Atlas Van lines U-95. I got the basic frame work done.
    I got a few questions.. Can i run a solid prop shaft or do i have to run the cable thing. ( sorry dont know the proper term)
    I plan on running a 3s 2200 Mah lipo battery ( i got alot from all the planes i drew)
    No idea on the motor or esc or even the weight yet
    total length will be 27 inch or 760 mm
    so any ideas will be welcome and i will not turn down any advice.
    this is where i am now
    LLoyd
  • rol243
    • Apr 2017
    • 1038
    The scale hydros were originally designed to run straight solid drive shafts and even today with the scale hydroplanes you must use a straight drive shaft in either solid metal or flexable straight configuration.
      The OP only needs to run a solid shaft if he races. If he doesn’t race then I suggest he run a 0.150” flex cable, much easier to set up. He will not get enough runtime with a single 2200 mAh pack, he should run two packs in parallel.
      Motor choice will will depend on how fast he wants to go, a 36x60 mm motor with a Kv around 2500 is one option. An ESC capable of 120-150 amps and 3S is another suggestion. OSE offers great quality components, so do other sellers.
      I strongly suggest that you speak with at least two boaters who run similar-sized boats for setup suggestions like CG, fin size, strut depth etc. Building an R/C model hydro exactly to full scale plans is a recipe for failure. Good luck with your project!
      • Cougar33
        • Feb 2018
        • 9
        i am going to guess that people use inrunners? I got alot of outrunners in my shop
        • rol243
          • Apr 2017
          • 1038
          nothing wrong with the outrunner motor as long as there is some more cooling to help keep it cool.
          • Peter A
            • 1624
            There are plans for the Atlas Van lines online.
            • Cougar33
              • Feb 2018
              • 9
              i looked at the plans for atlas van lines.. and was wondering why the 1/16 ply.. I am going to be fibreglassing it anyway.. could i build the boat using 1/8 balsa. Those plans are better than my design at the moment. so lets build that.
              Could i build the entire boat out of balsa? or are we going so fast we need the strength of the plywood? I am not going to try and break records here.. just trying to get into the water.
              I would think the fibreglass would provide enough strength.. wouldnt it?
              thanks for the help Peter
              • Cougar33
                • Feb 2018
                • 9
                OK made my decision.. I am going to be building the 1/8 Atlas van lines.. that looks easier to build and since i know nothing. Better to err on the side of caution,
                My first time around
                so i got this motor in a box doing nothing
                https://hobbyking.com/en_us/turnigy-...v-60-glow.html
                It was going to fly a top flite corsair.. Maybe it will work on this?
                this looks like a good esc..to start with
                https://hobbyking.com/en_us/hobbykin...c-4a-ubec.html
                now i know alot of people are serious racers here.. and i get it.. But i am new. and I dont even know how to drive these thing.I am talking with a guy from area now. and when the water becomes liquid again.. I am going out to talk with them. but i think i need a head start/
                will that motor work.. or do i need an different type of motor
                thanks for the imput
                  • 7512
                  Motor and ESC are totally wrong for a 1/8 scale hydro.
                  I'll PM you my cell number tomorrow and we can talk if you want.
                  • TRUCKPULL
                    • 3293
                    John
                    A 1/10 scale may be a better choice for Loyd to start out with.
                    Stock Motor, - Raider 150 ESC - and 4S
                    And about 1/10 the cost of an 1/8th scale.
                    Larry
                      • 7512
                      Thats what I was thinking....we'll probably talk tomorrow and see where he really wants to go.
                      • Peter A
                        • 1624
                        Ply is stronger, f/g inside is still a go. I think a 1/10 scale as suggested is a good idea. Balsa contruction while light even glassed will not hold up to the forces that water puts on a boat at speed, even if your speed aspirations are not great. Even a mild set up in a boat this scale would see you at 40+ mph. Hitting even a piece of floating wood at that speed would be very damaging to a balsa construction. Looks as if Doby wants to have a chat with you, he will be able to help you in a good direction so you can build a satisfying boat to play with. Feel free to ask more questions here, most of us would rather see you build something that will go well on a reasonable budget and be able to enjoy it.
                        • TRUCKPULL
                          • 3293
                          John
                          you coming to the swap meet tomorrow?
                          If Loyd is close, he can come too.
                          Sunday 11:00 AM
                          Port Credit Royal Canadian Legion Branch #82
                          35 Front Street North
                          Mississauga, ON
                          L5H 2E1
                          Larry
                            • 7512
                            Nope...god willing I'll be flying some RC Planes tomorrow, I think Lloyd is in Waterloo.
                            • Cougar33
                              • Feb 2018
                              • 9
                              well got my phone all in and not all lost.. the 1/8 scale has been shelved for the moment. 10 cell batteries?? are you guys nuts ( lol)
                              so cant do that at the moment.. the 1/10 scale is going to be looked at . maybe even a fast cat. the rtr one. but still would like to build. John made some real good point with the rtr version since it is all set ready to go.. I would not have to know what to do . just sort of plug and play thing.
                              I do like the looks of the hydros. Just have to make up my mind.. i would have thought my stuff would have worked. and all i need was to buy the running gear.
                              thanks for the help you guys.. it made it alot easier to solve issues when you have people willing to just talk to you
                              cheap motor and good esc are not on the hunt
