Considering another build and wanted your opinion on a hull...
    Another option that is simply a treat to work on with it large hatch opening
    https://www.offshoreelectrics.com/pr...prod=df-Cat-36
    Kind of a dihedral design but a bit wider than a Genisis(which BTW has all kinds of rude driving characteristics).
    • Linewbie
      • Apr 2017
      • 143
      MarineFe claims to have them in stock, heres the link if you are interested;
      https://marinefe.com/product/100-car...hter-cat-hull/
      Im thinking a build up from a bare hull. In no rush, so I can take my time. Maybe score parts in the Classifieds along the way. Leaning towards twins, but that will be decided later on. Although I've never worked with cf, I dont have a problem making mods to the hull. Just going to be a runner looking to go as fast as I can reliably, w/o trashing it all.
      • Newboater
        • 359
        Originally posted by Linewbie View Post
        I remember Big Fords Genesis and that it was very tight in the hull, sort of a pita to get his hands into. I realize narrow is good for speed, but I like a little more beam.
        I think only problem area is by the rudder mounting. It was snug in my River cat but I set the bind nuts into resin and now you can remove the rudder simply by removing the screws. It is an easy get around.
        • Linewbie
          • Apr 2017
          • 143
          I just had a ball aching bad time with the Apparation. Same problem, I went from the inside out with the Allen screws holding the rudder assembly on. Not about to do all that again.
            I forgot about Sandy at Marine FE. I’d go the Cheetah.
            • rayray9
              Steve Takes My Money
              • Sep 2016
              • 98
              • Newboater
                • 359
                You use bind nuts and trim one side down, then needle nose pliers to hold one of the points as they go in backwards spikes facing towards the front. You use antiseize on the screw then snug them up and pour in the resin. Once it is set up you remove the screws and the bind nuts are locked in easy peasy. all you gotta do is ask
                • Linewbie
                  • Apr 2017
                  • 143
                  Long Allen key held the screws while the nuts went on the outside. Not as pretty, but functional.
                  Yea srislash, Chetttah over Zonda. Lots of drag on that wide hull, no? Seems the Zonda, at least dimension wise would be the happy medium between the too skinny Genesis, and the Cheetah.
                  • dmitry100
                    • Mar 2015
                    • 1264
                    Why don't you grab the HPR 99 that was just listed in the For Sale category?
                    • Linewbie
                      • Apr 2017
                      • 143
                      Ive got about 1000 reasons why I cant.
                      • Peter A
                        • 1622
                        This is the same hull as Fantasm just a tad shorter. A friend just got one and said it had a good layup with decent meat in transom areas: http://www.dymotorshop.com/index.php...roducts_id=369
                        I think they had free shipping too, don’t quote me on that tho.
                        DYMotorshop has a new owner. Bill Oxidean. Saw something pop up about that recently on FB.
                        • Old School
                          • Aug 2017
                          • 686
                          A couple of months ago my son and I went through a similar episode with a small Sega cat. We made up a 0.250" aluminium plate drilled and tapped to take the rudder mount screws. The plate was bonded inside the transom, making it a breeze to disassemble the rudder at any time when needed.
                          • Old School
                            • Aug 2017
                            • 686
                            Originally posted by rayray9 View Post
                            I recently purchased two Arowana 32" mono bare hulls from the eBay store of this seller (far cheaper than buying retail through the store if he has the item listed on eBay). Shipping was expensive but then I only paid $40.00 usd for each hull. The quality of the build and finish is excellent although the hulls are not very thick. After a carbon inlay the hulls have stiffened up very well.
                              • 4338
                              I saw something pop up too, it was an email from the real owner of DYMotorshop asking someone else why everyone keeps emailing him about Bill Oxidean.
                                Ryan...
                                Lol, mmm
