UL1 propshaft ?
  • allenfbnracing1985
    • Jan 2018
    • 21
    UL1 propshaft ?
    Hey guys I have a ? Is it better to run the stuffing tube in the UL1 or is it better to run it without the stuffing tube also would chainsaw bar oil be a good lubricant for the flex cable thanks for all repays in advance
  • CraigP
    • May 2017
    • 1464
    Hmmm, I think you mean “liner”, not stuffing tube. There is no real winner, it’s what makes you feel better. As far as stuffing tube lubricants, many opinions on that to.. I recommend searching on the forum for “stuffing tube lubricants” and check out the thoughts of many...
    • rol243
      • Apr 2017
      • 1038
      Chainsaw Bar Lube is great for shaft lubes.
      • martin
        • 2881
        I like chainsaw bar lube as its stickier than most oils.
        • rol243
          • Apr 2017
          • 1038
          as its designed not to fling off a chainsaw chain as opposed to normal oils it seems to lubricate flexshafts and bushings quite well and its still there after a few water runs. i started using this oil type approx 30 years ago in my glow and gas racing days and all lead teflon bushings seemed to last very well. oh, Sthil bar lube is the brand.
          • JestDanny
            • Jan 2017
            • 176
            Bar oil hmmm never thought of that. Things I've used, ha ha Harley Davidson axel, bearing grease that was a nice pretty shade of blue, tractor grease molly bla bla or something allseason red, that spray lube for dirt bike chains, and tubes of white lithium . I think that it lol.
            PROBOAT BlackJack 24", ShockWave 26"
            MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint
            • CraigP
              • May 2017
              • 1464
              I’m using ProBoat marine grease and 3 in 1 oil. I put a lip seal on the end of the strut so I don’t lose any grease. The machine oil thins out the ProBoat grease, which I think is too thick. But without a seal, it would leak out the back very fast. That chainsaw lube sounds like something to try...
              • rol243
                • Apr 2017
                • 1038
                yes give the chain bar oil a try and see how you like it. its not messy like grease either.
                • Bp9145
                  • Jan 2016
                  • 1466
                  Thicker I think is good and if you say it's made not to fling off the chainsaw chain I think is great and will stay on the flex shaft longer which is good. How come I've never heard of this before. I'm certainly going to try it. I just wonder if it's too thick there is the possibility it might make the motor work a little harder to spin the shaft. . .but I'm definitely going to try it.
                  • rol243
                    • Apr 2017
                    • 1038
                    the bar oil is not that thick , i would compare it to something like 30 / 40 motor engine oil thickness. grease is thicker than oil.
                    • martin
                      • 2881
                      Yes its not as thick as you might think its just sticky for the reasons already given, Even Jeff wohlt has said he liked chainsaw bar oil for shafts.
                      • Bp9145
                        • Jan 2016
                        • 1466
                        then I'm going to give it a try. . .thanks guys. Again, learn something new
