not sure on the availability of smaller prop sizes but have a look at what the COCR props are made from.
prop treating
Well that's easy to answer. 30 year old tech has propelled this hull to a best of 106 mph, gps.eagle tree and radar, but not a sanctioned race. I am pretty sure it's the fastest PT 45 around. It is easy to get on plane,pulls a moderate amp draw and keeps the ESC's happy. All the other props I have tried produced some strange hull behavior and way to much time and money "chasing" issues. I am always open to new things but with this boat it took to long to get here.PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mph
The PT45 was designed around the prather and octura props that were available at the time. They do work well on that hull, and sport hydros tend to be picky when it comes to props. 106 is really moving for a sport hull. You need to bring that thing to one of the SAW events.
There are some hulls that don't get along with the new ABC props, but not many. When you get it all dialed, they are spectacular. Example: 4 cell rigger-45mm prop (1823-19-38)- 40.5k rpm peak -141mph through the traps at Legg.Brian "Snowman" Buaas
Team Castle Creations
NAMBA FE Chairman
45k rpm is nothing. Balancing that whole assembly like that is a waste of time. Every time the prop blade hits the water it’s off balance. Plus the shaft and drive dog are such small diameter that balancing them too are pointless. Now, balancing the collet is a worthwhile thing to do.Originally posted by CraigP View PostThey have those balances for airplane propellers that you can use with a shaft. It my understanding that they are more accurate than magnetic types, although I don’t use one, but I’m not trying to spin 45K either! This would probably work with a flex shaft, but the clearances needed to run the flex just makes balancing it a joke, IMO.
You guys got me thinking, a fairly dangerous thing! I think I would use the 3/16 hardened stub shaft, put a piece of flex on that just to make the bend. Then put a piece of straight shaft to the other end of the short flex. You’ll need a lathe to tool the hole into the straight shaft, so you can make a good brazed welded attachment. This would allow a bearing clearance for the majority of the drive line and only having it loose for the short piece of flex. What you guys think about that?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I’m not buying that... It only makes sense while the prop is IN the water. When it jumps out, due to rougher water, the prop overspins like crazy and that’s when balancing is the most important. There’s a reason why everyone balances their blades... Keep in mind that many people run laps, circling over the same water they just disrupted and pressing cornering speeds to the max. In that manner of running, prop cavitation and balancing is a big deal.
I have also read that Jorge, the German fellow doing 198mph in Saw, balances his entire rotating assembly as one unit. So I think it’s a relavent discussion.
I don’t ever worry about balancing my personal props perfect. I’ve seen no difference either way. Sharper and thinner makes more difference. If I sell a prop to someone it’s bakanced as best as I can do just do in case they check it then they can’t complain. My own stuff I don’t worry with it because it seems to work well for me either way. Obviously by looking at my builds I spend lots of time and details building these boats and if I felt like they needed that much attention, I would do that. I don’t like to leave any potential gain I could have out of the mix.
Bye compared a 198mph boat to sport running boats and much slower 100ish mph boats is kinda different. Just sayin.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
It’s not about a speed advantage, it goes to reliability, which is the topic of this thread. We all know you build a great boat, but many of us don’t just zip-zip straights, take it easy on the corners and zip-zip back again, while on glass water. This is NOT a knock on the way you and many others enjoy their boat, so please don’t get all bent out of shape. But running consecutive laps over progressively rougher water is a completely different world that zip-zipping. On most every video you have posted, you are running on glass and the prop never cavitates. On oval racing water, it is out almost as much as in the water, especially on the later laps. My data logger shows the prop rpm’s go from 32K to 42K, a big jump. The batteries unload up to a volt during these excursions. So there’s some big time dynamics in play under those conditions. That is the point I’m trying to make.
On full size hydros, props either broke hitting something in the water or on big time prop cavitation. Hardly ever when it’s hooked up proper, which concurs with what your saying. But in our style of running, we have to contend with cavitation to a big degree.
Originally posted by CraigP View PostIt’s not about a speed advantage, it goes to reliability, which is the topic of this thread. We all know you build a great boat, but many of us don’t just zip-zip straights, take it easy on the corners and zip-zip back again, while on glass water. This is NOT a knock on the way you and many others enjoy their boat, so please don’t get all bent out of shape. But running consecutive laps over progressively rougher water is a completely different world that zip-zipping. On most every video you have posted, you are running on glass and the prop never cavitates. On oval racing water, it is out almost as much as in the water, especially on the later laps. My data logger shows the prop rpm’s go from 32K to 42K, a big jump. The batteries unload up to a volt during these excursions. So there’s some big time dynamics in play under those conditions. That is the point I’m trying to make.
No getting bent out of shape here. I was just stating my experience based on the original posters boat. I don’t thing he’s doing oval at 105mph. Was just basing this off the original topic. I didn’t know (or didn’t realize) we gravitated towards oval boating talk. I’ll see myself out lol32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Well Bodycote just quoted me $450.00 to do the props {3} that I have. Ummmmm...I don't think so. I will just keep a few in stock this year . LOLPT-45, 109mph, finally gave up after last bad crash
Chris Craft 16 mph
