Where can I find those through hull gromets used when passing
  • Linewbie
    • Apr 2017
    • 143
    a cooling line through the transom? I can't find them anywhere in the OSE Store website. I'm about to undertake an Apparition build from a bare hull up, and I would like to order everything in one shot. Rather unlikely, I know....Thanks.
  • Bp9145
    • Jan 2016
    • 1466
    You should find everything related to watercooling like hoses, pickups. . .etc under cooling system parts
      You really don’t need a grommet if you drill the hole a little smaller than the hose and chamfer the outside.
      • Linewbie
        • Apr 2017
        • 143
        First place I looked Bp. NG. I'm not looking for the bulkhead fitting that is used for exiting the hull after cooling the motor, and esc, rather the grommet used when the water line just comes off the rudder and into usually through the transom. It insulates the line from chafing. Probably not 100% necessary, but it looks alot nicer than just the hose going through the transom. Thanks though.
        ETA-yup kfxguy, you are correct. It wont let water past it either way, thanks.
          And I do not recommend the through hill fitting that has a nipple on each end. It’s a pain in the rear to connect the hose on the inside of that boat and you’ll need a zip tie or clamp to hold it on. Or it’ll pop off and flood your boat. So stay away from those and just run one cooling like in it. Here’s a carbon version of that hull and I did use a grommet on this one. You’ll need to jb weld it in a wait a day or so and drill it out a tad.
          • Linewbie
            • Apr 2017
            • 143
            Thats exactly the part, right there. Guess I will do without. Thanks for the heads up on the other fittings, I have them on my other two boats, and have zip ties the coolant lines as suggested. 102 mph out of that bad boy, damn!!! I'm going to have t check that out further. Can I tap you as a resource for the build? Any vids posted on Youtube of your Rivercat?
            Actually just found your boat there, white canopy?
              Yes I’ve had a few with white canopy’s. Here a 102mph video. You can go to my channel and watch the other vids and yea I don’t mind helping you set it up. I’ve definitely got some experience with these hulls lol
              • Linewbie
                • Apr 2017
                • 143
                Ive been checking out the vids. Thanks.
                • MarkF
                  dinogylipos.com
                  • Mar 2008
                  • 988
                  This is the one I use.
                  https://www.offshoreelectrics.com/pr...prod=ose-80898
                  Mark
                  • 785boats
                    Wet Track Racing
                    • 3423
                    These guys sell those gromets.
                    https://www.ebay.com.au/itm/2pcs-alu...OycqnBERgi6m_w
                    • Linewbie
                      • Apr 2017
                      • 143
                      Different ones Mark, thanks though.
                      Great 785, thanks, that's them.
                      • MarkF
                        dinogylipos.com
                        • Mar 2008
                        • 988
                        Yea those are the kind the gas guys use and they don't care if water get in through them. Iv'e never tried them so maybe they are ok.
                        Mark
                          I'm getting to the point of just gluing in a brass tube and jam on the silicone tubing. Looks neat enough.
                          I've used the aluminum threaded through Hull fittings before and when I go to take them out for a repaint they were seized in there. Had to drill one out on the Cheetah.
                          Lots of ways to get it done.
                          • 785boats
                            Wet Track Racing
                            • 3423
                            Ray.
                            I also do that sometimes. But mostly I just do what was suggested in post #3. Drill a slightly smaller hole & feed the tube through. Plus I add a small drop of thin CA glue around it to seal.
