I vaguely remember seeing somewhere (I think on this site) a tutorial on polishing flexshafts. What are the benefits of doing this? Is it worth it?
Polishing flexshaft?
Thanks for the responses guys. Next question, how do I go about polishing them. I can't find the tutorial I mentioned earlier, the only thing I remember was to put them in a drill. What do I secure the other end to? Will it make a difference if using liners?
Then I work up in grit to polishing paper. I avoid the end that goes in the coupler. Clean, clean and clean it again before using it.
For me polishing a flexshaft is not that important but I make sure mine is always cleaned and greased up after a run. I have quite a few boats and some I haven't ran in years and only to find a rusted shaft because I didn't grease them up after a day's running. . .a lesson learned. So now at the end of the day I never put a boat away without cleaning the flex and heavily greasing it up since I don't know if I'll use it within a few days, months or a few years. But I'm only sport running and don't need the higher demands and needs of racers. But then again it doesn't hurt and as Craig mentioned, also polishing it with care. So is it worth it? For me no. . . having a clean and well greased shaft is of greater importance for me.Originally posted by hughb View PostI vaguely remember seeing somewhere (I think on this site) a tutorial on polishing flexshafts. What are the benefits of doing this? Is it worth it?
As was stated after time the shaft will wear and polish itself so to speak. On new shafts I chuck them in a hand drill and wetsand with 220-320-400 and finish with 600 grit. Use an airhose then WD40, and on to your regular lube. This accelerates and limits the drag that normal wear from running does.Your just polishing the high spots off, no need to reduce the shaft diameter significantly. Not rocket science just attention to details.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
I start with 400 grit and wd40 and work my way to 1000 grit. Then several sessions of mothers metal polish applied on a microfiber cloth.
try Valve Grinding Paiste as the cutting lube and use an old or spare brass shaft log with a slight bend in it and work up and down with the drill with plenty of paiste on the shaft. this job takes only approx 5 minutes and the shaft is very smooth . clean the shaft in some Petrol /Gas when finished.
