My TFL Genesis Chronicles
  • emspjay
    • Sep 2017
    • 411
    Hello everyone first post and trying not to make it too long. Got into R/C FE in the 80's and 90's then got out of the hobby for many years. Last few years been buying the old ones off Ebay and fixing them up, some converted to small brushless set ups. I wanted to go faster so decided I should get a modern boat (Genesis). I'm new to the high power brushless world, here is what happened so far.
    I live on a 50 foot wide canal and do only straight high speed passes no high speed turns.
    Genesis (one that looks like the real Aqua mania) stock SSS 2050kv, 120a Turnigy ESC, single 6s 45c 4500mAh on left side.
    First run break plastic prop in about 30 seconds.
    Second run 6s with X440 lost rudder pin in about 1 minute, fixed that broke flex cable in about another minute but I think I hit some weeds.
    Third run 6s I had adjusted the strut and way too low, it was fast and stable but too wet and too many amps for the 120a ESC and it burnt up.
    Ordered HW 180a ESC and program card, UBEC, , and a bunch of props, x442, x445, m445, x642.
    Forth run 4s with 180a ESC (3.75 timing), UBEC (red wire cut on ESC RX plug), still X440, single 4s 45c 4500mAh on left side with strut raised ran great but I want more speed.
    Fifth run 4s same set up as forth run before but I raised the strut again but I think I raised it too much handling sucks, porpoise really bad.
    Now on order, everything to convert to 3/16 flex cable, dual water pickup rudder and all that stuff for separate cooling, leopard 3074 1650kv motor (might be starting issue with Ebay on the motor, been two weeks and have not received), will just be buying from here from now on, I got a bunch of this stuff from here fast shipping no problems.
    So am I heading in the right direction to get this boat running good on 6s??
    Thanks Jason
  • Tails Up
    • May 2016
    • 51
    Welcome aboard! First of all.It looks to me like you are doing good,but I have only been in FE about a year. I would also try a 440/3 prop. Thats what I use on my BJ V3. It works well on 2000kv 6S setup.
    • MadProps
      • Mar 2017
      • 236
      my genesis loves the octura x45mm especially in light choppy water...
      this hull being so skinny wants to roll as Im sure you found out, as it begins to bounce around input a "little" left turn it brings the left sponson down and you can then increase to full speed
      • emspjay
        • Sep 2017
        • 411
        Thank you tails up and madprops for the reply's! I will have to try those props. If I do not end up receiving that 3074 1650kv motor from Ebay do you think I should go with something around 4082 1600kv with 6s? I really want to try and run the boat again tomorrow with the stock 2050kv on 6s but I do not want to cook another ESC. With my current set up do you think I can run the stock 2050kv motor on 6s?
        • MadProps
          • Mar 2017
          • 236
          I had a Turnigy 120a esc but things got hot on 6s so take it easy
          then ran a Turnigy 180A ESC and temps dropped
          • emspjay
            • Sep 2017
            • 411
            So my last run was with stock motor SSS 2050kv, 180 ESC 3.75 timing with UBEC, single 6s 45c 4500mAh on left side, new 3/16 flex shaft, same x440, and now dual cooling. Boat ran great low temps but started to "dance a bit at high speed". I think next run will be with 6s 45c 4500mAh on both sides (in parallel). I hope that having battery's on both side will help handling? Or maybe I will need to drop the strut a little bit?? Also has anybody sealed or closed off the voids in the back of the hull?? I feel like those might be catching water from wakes or waves??? And that might be causing the side to side dancing at speed??
            • MadProps
              • Mar 2017
              • 236
              I filled the two voids for twin stingers , you will feel the improvement at low speeds hole shots and turning....
              as to your bouncing this is what Ive found ....as you are increasing speed and it starts mishandling input a little left turn
              sounds like it maybe torque roll I experience this when I raise my strut high with a big prop but dont want to slow down my hull so I just add the left input when accelerating to lay the hull down and get up on step
              edit: if your genesis runs with out miss handling in choppy water it is the torque roll that choppy water touches the right sponson and sticks it to the water which stops the bad handling
              • emspjay
                • Sep 2017
                • 411
                Update! ran with both 6s batteries and handling is better but still gets dancy at high speeds but not as bad. I did not replace the drive tube and only pulled out the Teflon and put in the 3/16 flex shaft and now I get lots of water in the hull, is that because I did not put in a bigger tube and new Teflon??
                • emspjay
                  • Sep 2017
                  • 411
                  Another update, greased the crap out of the flex shaft (not as much water was in the hull after the run), flat water on the canal, run was with stock motor SSS 2050kv, 180 ESC 3.75 timing with UBEC, two 6s 45c 4500mAh batteries, 3/16 flex shaft, same x440, and dual cooling (dual cool rudder from here OSE). Ran it a bit longer today with the two batteries and temps got higher (kinda expect that). Still dancing at high speed, it looked like it was more like jumping out out the water when I hit WOT (long gradual increase in speed before I hit WOT) and I think it still completely jumped out of the water a few times!! So I got two BIG batteries mounted on the stock battery holders, do they need to go farther forward to help the CG??? Or should my strut go higher or lower?? Right now if I lay the boat on a flat table the strut hits the table and the back of the hull is about 2mm above the table (I would think that would put more of the front hull in the water). Seems like I need more set up on the strut and weight placement. Also since the temps got higher today I think I'm going to order a bigger lower KV motor tonight (from here OSE) because I don't want to kill another ESC. SO what do you guys think?? And thanks in advance!
                  Edit: More info. Once the batteries ran down a bit the jumping and handling problem really went away. So is this huge prop torque problem?
                  • rol243
                    • Apr 2017
                    • 1038
                    firstly is the prop a 2 or 3 blade 440 ? sounds like your c.o.g. balance and or your strut height is not right. which direction is this hull bouncy ie; north to south or east to west ? can you show a pic of the rear of this hull ?
                    • MadProps
                      • Mar 2017
                      • 236
                      the Genesis can almost flip vertical from a hole shot, the higher you raise the strut the more roll you will experience with this hull
                      I think you have 2 problems making it not handle well, .....agree with rol243 COG......I believe first batteries need to be moved back ...., dont know what your batteries weigh but im running 2 3s 5000mah or 4s 5000mah and the top of my batteries are inline with the rear of my motor and also seems these hulls like some positive trim to your strut 1-1.5mm....your results may vary I should also mention I could not achive enough positive trim until I filed out the strut to allow more adjustment see photo below
                      • emspjay
                        • Sep 2017
                        • 411
                        Hello guys thanks for the responses. It is a 2 blade 440. I have attached some pics off the boats back end and batteries. I moved the strut up again so the hull no touches the bench but I have not run it like this yet it was 0nly 1 or 2mm lower before.
                        • MadProps
                          • Mar 2017
                          • 236
                          be aware many of of found that the HK Genesis stock SSS motor wont last long on 6s. I ran 6s only and got 25-30 runs before it died.......also bout a HK Pursuit with an SSS motor and it smoked after 6 runs on 6s .....your results may vary
                          my battery placement....
                          • emspjay
                            • Sep 2017
                            • 411
                            Yep your packs are farther back than mine I will have to try that. I ordered a leopard 4082 1600kv motor and back ring for mounting Friday night. So I think I will wait for my new motor before I run it again. Should I run a bigger prop with that motor? I got some others, X442, M445, and M447. And what timing should I run with that motor?
                            • rol243
                              • Apr 2017
                              • 1038
                              a D wind motor should run very low timing such as 0 degrees to 3.5 max. are you leaving a gap between the drive dog and strut end ?
