Amp draw Q Hydro
  • CraigP
    • May 2017
    • 1464
    Originally posted by ezhitz View Post
    I wanted to know what kind I amp draws can you expect to see from a Q Hydro. I do understand I it will depend on prop selection weight boat running wet these kind of factures. The boat is a sport 40 whiplash motor Neu 1530 .75y prop tried aluminum 2 blade 4814 48mm batteries revolectrix 60c 4400 mah 2p rtr weight just under 12lbs. Had a turnigy 240 esc in it until it stopped working so I tried my 220amp swordfish with data logging and thought the amps would be lower then my 4s p hydro. What seem to lower the amps was running an older set of turnigy 4000mah 30c.
    The boat needs more set up as it seems to hop a little https://youtu.be/l1gXqNqWVIE
    Revolectrix 4400mah 60c[ATTACH=CONFIG]153895[/ATTACH]
    Turnigy 4000mah 30c[ATTACH=CONFIG]153896[/ATTACH]
    What's the voltage you're running on the Q Sport? The boat is looking pretty good to me! Got some chop on the water and the hull is handling it very well...
    • ezhitz
      • Aug 2009
      • 466
      Yes they are but its the older SF220 not the newest one.
      :canada
        Wow. My older sf220 would shut down all the time.
        Never got it ready for last weekend. Looks like I have to wait until next year.
        When I'm in Vegas I'll check out some of their setups to see if I can get more ideas.
        Nice results so far. You might notice less hopping when racing with others when water is rougher, I did.
