HK/TFL Pursuit Mods
  • Hydrocarbon82
    • Apr 2016
    • 68
    HK/TFL Pursuit Mods
    The HK Pursuit was on sale so...I got it in 5 days from AZ to WI, zero damage. Their website doesn't show updated pictures, so I hope this helps somebody.
    The first thing I did was order an OSE single-piece driveshaft. This version uses a full 3/16" shaft, 1/4-3/16" teflon stinger bushings, and 7mm stuffing tube with teflon liner. I got it set up with a Flycolor/Raider 150A with the stock motor & M445 and it only did 36mph - really disappointing. I put in a GoolRC 3674 2250kv and that bumped it up to a consistent 43.3mph, but the ESC was thermaling on occasion. Batteries are Gens Ace 5500mAh 45C 4S.
    I decided to reconfigure a few things. First was the stinger - I replaced the lead teflon with 1/4" x 0.014" & 7/32" brass tube to replicate a Speedmaster bushing. The bushings came out with a drift & hammer, but the brass needed some mild sanding. While doing that I noticed the stuffing tube was drilled nearly 1/8" off from the stinger centerline! TFL used a nice silicone gromit, but it doesn't let the tube move down low enough. I just hogged out the hole & added some silicone.
    After that I put new SS bearings in the motor. I also changed from 4mm to 5.5mm connectors on the motor. The last thing was to shorten that strut turnbuckle on my lathe. It was maxing out while the strut was even & has more adjustment now.
    Next test lead to zero esc thermaling, much cooler motor, and an increase to 48.5mph. It was a busy day on the lake with some mild chop. It still seemed to ride perfect in the water, so I decided just to enjoy it rather than try strut adjustments. Keep in mind this motor is nothing like a Leopard. It's a $23 motor and I'm fine with performance since it's a sport boat.
    To condense speed info:
    36mph - stock 1620kv motor, M445, mis-aligned strut
    43mph - 3674 2250kv motor, M445, mis-aligned strut
    48mph - 3674 2250kv motor, M445, speedmaster-style bushing
    39mph - same as last but with 2x SPC 2S 5000mAh 40C instead of Gens Ace 4S
  • runningman
    • Mar 2016
    • 103
    What runtimes do you have?
      Good improvements, nothing wrong with 48mph. Good work
      • iop65
        • Mar 2013
        • 367
        Prop needs some sharpening
        • Hydrocarbon82
          • Apr 2016
          • 68
          I didn't want to go too far since it's just a sport boat prop. I know it's far from a "bad job", as this M445 is on par with my X642. It was a little faster on my Revolt and a little slower on my Shockwave. The guy who sold me the X642 thinned the heck out of it, sharpened it like a steak knife, de-tongued it, and claimed to have checked it one of those expensive prop modding/measuring rigs.
          As far as run times, I can't really say since I mix full throttle passes along with holeshots & slow sweepers to entertain the kids & dogs. The first runs before the stinger mod were 5 mins max & runs after felt like 10 mins. I actually pulled it in before LVC because I thought it wasn't working.
          The next step is my custom datalogger. I could have bought an Eagletree, but I wanted bluetooth so I don't need to pull the hatch. It's $15 in parts and will use a 200A version of the Allegro amp sensor, a 10hz ublox GPS, and IC-type thermisters. I also want an RPM sensor, either optical or hall.
          • runningman
            • Mar 2016
            • 103
            Interesting. I put 2200kv motor and with m440/3 prop got 72.9km/h. on 2x5000mah batteries. But not sure if my run times more than 5 min. m445 should draw more umps on more kv motor. No?
            • MadProps
              • Mar 2017
              • 236
              whats the stinger mod you did?
              • runningman
                • Mar 2016
                • 103
                Just O-ring mode. Nothing special.
                • MadProps
                  • Mar 2017
                  • 236
                  OK....I was trying to account for your increase in run times
                  edit: possibly you were running a little wet and then you changed the angle a wee bit positive doing the mod?
                  • boatsrnew2me
                    • Oct 2016
                    • 474
                    • runningman
                      • Mar 2016
                      • 103
                      I think you need to ask Hydrocarbon82, not me :)
                      • MadProps
                        • Mar 2017
                        • 236
                        Originally posted by boatsrnew2me View Post
                        Mine ready for a evening run [ATTACH=CONFIG]153874[/ATTACH]
                        what motor are you running?
                        I just tested mine with a new 4082 1600kv 42mm octura 2 min ago, runs great, started to do a little tuning then it started raining on me ....will also try a 45mm octura when the rain stops
                        good luck on the run tonite!
                        • Hydrocarbon82
                          • Apr 2016
                          • 68
                          Looks like a healthy 6S setup, Boatsrnew.
                          Straightening the flex cable's transom exit & replacing the teflon bushings with 2pc brass bushings. The cable has 1 bend now instead of 3, so a bit less friction at 30k rpm.
                          I eyeballed the strut as level as before. I think it's just good a better combination of strut angle, motor connectors, bearings, and flexshaft friction.
                          I'm not a prop guy, but what I've seen shows a 445/2's load similar to a 440/3. 73kmh translates to 45mph. Before the mods I considered a 442/2 due to overheating. Most people seem to run ~2000kv in a 4S Pursuit with an M445, so we're probably near the limit.
                          • MadProps
                            • Mar 2017
                            • 236
                            ya I got members crossed
                            • boatsrnew2me
                              • Oct 2016
                              • 474
                              leopard 4082 1600kv with a ose b&s x645 . my best run has been 57.4 . todays best 52.1 ,i could use higher c lipos . most are 50c .achieved my best speed on my turnigy heavy duty 3s 5000 60c set .they are some stout lipos for sure .
                              motor barely gets warm ,highest i have seen is 105 ,most times high 90`s . the flycolor 150 esc gets a bit warmer then that ,i have seen 150 on the caps and 135 on the sink.
                              after a few hard passes lvc kicks in and i have to slow down or stop for a few until the lipos recover ,then its back to the races .the flycolor esc does a good job of protecting my lipos so that doesnt bother me .
                              i set my timer for 5 minutes and my lipos come in at about 30%. i have never tried the front lipo tray ,i went this way because i already had a bunch of 3s lipos for my other boats .
