Rudder length sport hydro
  • ezhitz
    • Aug 2009
    • 466
    I was wondering if there is a rule of thumb for the length of rudder below the strut. Or is it just a matter of keep trimming until you find what the boat needs to turn and run straight.
    Thanks Jack
    :canada
  • TRUCKPULL
    • 3293
    No rule of thumb, it depends on the size and hull design.
    You could buy two rudders, for when you find that you have cut too much off.
    Larry
    • rayzerdesigns
      • Dec 2013
      • 1228
      Good rule of thumb is 1"below bottom of prop
      • rol243
        • Apr 2017
        • 1038
        not sure if 1 inch of rudder below strut would be sufficient for oval , maybe saw . rule of thumb is normally start with the longest length and gradually cut 1/4 inch per time until you still have good turning control .
        • rayzerdesigns
          • Dec 2013
          • 1228
          I don't do anything but race.. even offshore.. 1 inch below bottom of prop is plenty.. I'm sure my results will back that up.. gas or electric
          • rayzerdesigns
            • Dec 2013
            • 1228
            And is u noticed I said bottom of prop not strut
              • 4340
              Just for clarification, 1" below bottom of the prop blade at its lowest position?
              • rayzerdesigns
                • Dec 2013
                • 1228
                Correct
                • rol243
                  • Apr 2017
                  • 1038
                  just remember if your running a Lifting Prop there will be less rudder in the water at speed.
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 988
                    I will say 1 to 1.5" below prop. I like 1.5 on some monos and 1" on others. This is boat dependent. I start at 1.5" on hydros too and start cutting down but stop at 1" below the prop. Having a longer rudder helps in choppy water in the turns and could help keep you right side up. The difference is only a few mph so don't get to caught up in rudder lengths unless you're longer than 1.5"
                    Mark
                    • rol243
                      • Apr 2017
                      • 1038
                      maybe electric sport hydros don,t need much rudder in the water but i just measured my Gas sport hydros prop depth and it is 2 1/2 inches below the lowest prop blade [ prop being 2917 ] i had a shorter rudder on this hydro but i didn,t want to turn sharp around the bouys , the longer rudder blade helped alot.
                        There is no one-size-fits-all measurement, that is why there are rules of thumb* which are not intended to be gospel. Larger, heavier boats may need a deeper rudder than an N2 mono does. I know that if I try to run a rudder 1" below the prop arc I will unhook in turns when racing my hydros on the rough water we have here in Texas. The width of the rudder matters too, a .20-sized rudder on a Q hydro may need more depth to have adequate rudder area in the water. How tight the turns are matters too, non-NAMBA/IMPBA members may want to turn tighter, and a 1" rudder may not work for them. If interested in the 'optimum' rudder length for your boat and style of running, I like post #2 above.
                        * Wikipedia: A rule of thumb is a principle with broad application that is not intended to be strictly accurate or reliable for every situation.
                        • ezhitz
                          • Aug 2009
                          • 466
                          Thanks for all the great answers. My rudder is about one inch below so I will leave it alone. I do mostly fun run but it is on a impba course so my turns are not that tight.
                          :canada
