thrust bearing
  • snaps
    • Mar 2015
    • 39
    thrust bearing
    Hi all.Has anyone had a thrust bearing melt?what would cause this?i had brand new thrust washer between motor and collet.3Piece one with red nylon bearing case.After 6 laps it melted the nylon.only thing that was hot was the collet.Boat has all new running gear and is free to spin by hand
  • Prodrvr
    • Jul 2015
    • 701
    You don't use a thrust bearing with a nylon cage.
    • rol243
      • Apr 2017
      • 1038
      yes try a full metal thrust bearing set and leave a tiny gap between the collet and motor so its not spinning all the time when these no load put on it also keep it well oiled.
      • snaps
        • Mar 2015
        • 39
        I dont want to mention any names but Why do well known rc boat shops sell them?
        • Prodrvr
          • Jul 2015
          • 701
          Good question. I have no answer for that one.
          • snaps
            • Mar 2015
            • 39
            I am confused.Please explain "when there is no load on it"IMO isnt a boat always under load when running?
            • snaps
              • Mar 2015
              • 39
              Thanks for replys.I will try metal one and hope it solves the issue
              • rol243
                • Apr 2017
                • 1038
                there is no load on the collet to motor when the drive shaft is either not connected or the boat is out of the water. this is why you want the thrust bearing to work only when its needed not all the time , thats how these little bearings wear out quick.
