Guys, is a 30c to 70c burst lipo better than a 60c only battery pack ?
C rate battery ?
It's just gamesmenship with words for marketing. They want to put a big number on their battery to attract customers. Normally a battery that has a single rating is better, because it states the amp draw you can run at until the discharge point. "Surge Ratings" can be vague, and don't give the user a good idea for how long the battery can maintain that rate. I think the car guys might have more need for a dual rated battery. Boats pull power, all the time!
thanks CraigP, i have been looking for some 2s packs to make up 1 x 4s sized pack eg; 2 x 4000 mah - 4s = 1 x 8000 mah 4s pack. most of the 2 s packs i have seen have rather low c rates other than the others in question that state something like 30 to 70 c burst. i would like a 60c / 4000 mah / 2s pack.x 2 of.
Well, 60c on a 4000mah battery is 240 amps... the question is: how many amps do you need? Also, basic runtime calculations:
4000mah=4ah that means you can pull 4 amps for one hour, but that completely depletes the battery 100%. You can't do that. So it needs to be pro-rated by 25%, so 4(.75)=3. So you actually pull 3 amps for one hour, and leave a 25% reserve. One hour is 60 minutes. So the runtime calculation is: 3(60)/240= 0.75 minutes, or 45 seconds! So my question is, how much current do you really need? That's a really short run time!
CraigP, i am only getting no more than 2 minutes from my 5500 and 5800 mah / 65c / 4s packs so i was hoping if i went to 2 x 2s packs of say 4000 mah each and a good c rate size i would get more run time and not over heat the packs. i don,t want to much run times just enough for a good race plus mill time . these packs will be pushing something like a 4060 - 2450 kv in a rigger.
Ok, let's figure what you know...
Let's figure the middle of those two packs, or 5600mah. So that's 5.6AH. Now solve for the current, based on the known 2-minute runtime. 5.6*0.75= 4.2ah, (save 25%) so 4.2(60)/2=126A
This is a good method to determine your real current draw, in absence of a data logger. So 126A means your current battery is running a C-Rate of 126/4.2=30, or 30C.
The higher C-Rate can be because better conductors are used inside the battery or the battery chemistry has a lower Internal Resistance. Now if you want the battery to come in cooler, then that's more a factor of IR. Let me show you the math for that... Let's assume an IR of 0.0015 Ohm, or 1.5milliohm. The formula is: W=I^R So, 126*126*0.0015=19.85W, which will get a battery warm! Look what it is at 2.5milliohm: 126*126*0.0025=39.7W!
So as you can see, IR, is the dominant factor, although higher C-Rate may play a factor, but hard to quantify. But looking at the numbers, anything over 60C is probably money not well spent. I hope that helps you!
