TS2 weight
  • ice329
    • 792
    TS2 weight
    Any know or remember what the TS2's hulls weight was? Trying to see if the new model is a lighter or heavier Hull. The new wooden one is 4 pounds.
  • Darin Jordan
    • 8332
    I don't recall the empty weight, but mine was 5lbs 10.4oz RTR w/ 4S1P 4350mah 20C cells, REK Lower, and an SV27 motor setup...
    My WoodStuff hull is about 8 oz lighter with the same setup, but it races faster when I use a single Elite 4S1P 5300mah Lipos pack, as opposed to the 4S1P 4500 mah pack...
    I'm not too hung up on weight... It's only part of the equation, and sometimes more IS better...
    The VS1 should handle like crazy... Much better than the TS-2...
    Darin E. Jordan - Renton, WA
    • ice329
      • 792
      I was just curious and looked for the TS2's listed weight everyplace. I finally made some major adjustments, got a new motor mount from the captain, rebuilt the box and added a high torkservo, its about ready to give it another go. I need a loose on the edge ride and the set up I had was way to stable.. Thanks for the relpy
