Prop for Smash Shark and Leopard 4074 2200kv?
  • Dashunde
    • Sep 2014
    • 53
    I'm about done building my new Smash Shark and its time finalize my OSE order for the last bits and pieces, unfortunately there isn't a whole lot of info out there on this boat.
    Its 4s 5000's 50c thru a Sea King 180a.
    I need a good prop. I read somewhere this hull works well with a 3-blade, but I don't know the specifics?
    I dont want it running hot or short run times, this is a basher for around the dock, but I don't want to give up a bunch of top end either.
    Also need..
    Longer rudder (that either mounts to existing TFL bracket, or at least uses the same holes + a couple new holes if needed?)
    One-piece cable/shaft
    Larger turn fins
    Trim tabs
    I'm not overly familiar with boats (particularly what size of things I should buy) and most of the info I've found on alternative parts for this boat refer back to HKing and its old or out of stock... and I'd much rather buy from OSE anyway.
    What would you add to it?
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 988
    I wouldn't upgrade anything until you decide it needs it. The one piece cable is a good idea but I don't know you need anything else until you run the boat. That motor combo works great on an Octura 447 prop for racing. A 3 blade pulls the corners harder for racing but eats up run time. Stick with a 2 blade. If you want more runtime you need to run a 445 or 442 prop.
    Mark
    • Rc4me
      • Jul 2017
      • 67
      I orded a dual rudder for mine from ose
      Part number ose-83252 i just use one side of the bracket. Best upgrade i did to it. It turns so much better.
      I also installed one piece driveline...and the trim tabs...running 6s 1450kv 4082 turning a 44x1.6 temps are 117 basically around.
      • Dashunde
        • Sep 2014
        • 53
        Ok, ran the boat on the stock 38mm prop with decent maiden results overall... by that I mean everything worked, nothing went wrong, it didn't leak from bolts or seals, and it moved out pretty well and didn't exhibit any really obnoxious behaviours.
        Straights/speed
        Nearing full speed on a somewhat small'ish pond the bow wont stay down, but it runs straight and doesn't lean.
        Cog is at 10.5" from transom, 32" total to nose. (~32%)
        Stinger is dead level with keel.
        Turns:
        Wallows/rocks a lot in the turns in mild chop (conditions similar to race course, our cove or pond with mild winds)
        Spun out a time or two.
        Turns left fairly well at speed.
        Almost entirely refuses to turn left at slow speed (problematic when maneuvering around dock(s)
        Stock turn fins are trailing at 45deg - should they be straight vertical?
        A larger rudder is obvious and on my list, will that help correct the wallowing or is that something else?
        Prop
        Sorely needs a bigger prop
        Lots of cavitation
        All temps were barely warm and I got ~10 minutes of goofing around in the small'ish pond on new pair of GensAce 2s 5000's (20% remained when charged)
        I have no idea which prop to get, or even what type.. X, M, or 3-blade.
        I'll mostly run this thing in tighter areas, smaller ponds and in our cove amongst the docks.
        A quick hole-shot and tight mid-speed handling is more important that pure top speed, further backed up by its tendency for bow rise at speed anyway.
        Thoughts?
        ps.. I do have a unusual amount of water backing up the tube between the cable and teflon when its sitting still, and it pumped plenty of grease out between the hull and stinger.
        Is that normal or do I have a fit problem back there? None of my smaller boats do this..
        On my smaller boats I've been using the generic blue "marine" grease from Walmart that I use on my real boats and trailer bearings, etc.
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 988
          If you're running a 38mm prop then a X 440 3 blade would be the next size up and give you more hole shot. But you will shorten runtime 2 or 3 minutes. Most don't get more than 4 or 5 minutes on there boats.
          Put the turn fins straight down. If you're spinning out and wallowing this will help. Your cog is too far back if bow won't stay down.
          Mark
          • 785boats
            Wet Track Racing
            • 3423
            Rob.
            As mark stated, an Octura 440/3 is a good prop. I sort of half de tongue mine which still retains the torque & allows toe motor to rev out a bit more at full throttle.
            Too large of a diameter prop on these slender hulls can induce excessive torque roll. I've also had good success with a CNC 4214/3 with your setup & boat size.
            We found that a larger rudder certainly made a big difference in the turns with the Smash Shark.
            The gap between the transom & the stinger can be sealed with some silicone sealer.
            About 1 degree of negative angle on the stinger will help keep the nose down.
            • Dashunde
              • Sep 2014
              • 53
              Thanks all.
              What is the correct 1-piece cable from OSE? There are a couple 3/16 to pick from..
              Long shaft or shorter shaft then there is this one for the Voracity with similar dimensions.
              The stock shaft is ~3.00 inches overall including the square drive part, the bushing contact area/drive dog/plus prop/nut is about 2.25".
              BUT... here is a oddity maybe you folks with much more experience can clear up.. The stock shaft measures 0.184" and its cable is ~.185" and it does NOT fit through the stinger bushing.
              So... how are any of these 3/16 (.187") 1-piece assembly's supposed to fit through a ~.185" stinger bushing?
              • a428q
                • Jun 2013
                • 2
                Had same problem. Cordless drill end sandpaper worked. Shaft in the drill sand and polish until you happy with result.
                Sent from my SM-G920T using Tapatalk
                • Rc4me
                  • Jul 2017
                  • 67
                  I bought an ose 18in and cut to fit. I didnt have that issue. The flex was tight going in but after the first run it was fine. Im assuming it wore itself in.
                  • Dashunde
                    • Sep 2014
                    • 53
                    Well... I bought a 440/3, put a bunch of work into it, and it ran great.. until that damn grub screw bullet that holds the prop onto the unthreaded shaft let my new prop fall 30ft to the bottom of our cove (murky, no hope). Apparently I didnt get the grub straight and tight. :/
                    So no matter what it takes.. its getting a one-piece ose shaft along with another 440/3.
                    I'm considering replacing the stock tfl stinger bushing along with the shaft for a better shaft/bushing fit without any sanding & polishing to make it fit the odd undersized stock bushing.
                    Anyone have a clue what the OD is on a stock TFL 3/16 stinger bushing? I'd rather sand the outside of the bushing to fit the stinger instead of sanding the new shaft and cable to fit the stock bushing.
                    • CraigP
                      • May 2017
                      • 1464
                      I use Locktite a Blue on all those grub screws. I also use it on the drive dog to the prop shaft. Locktite your shaft saver collar too if your using one
                      • rol243
                        • Apr 2017
                        • 1038
                        the use of Locktite is a must for any motorized craft.
                        • 785boats
                          Wet Track Racing
                          • 3423
                          Sorry to hear about your loss of prop.
                          The "Pond Gods" have stolen many of my props & shafts too over the years.
                          I'm glad you like the way the prop works on that set up.
                          • rol243
                            • Apr 2017
                            • 1038
                            its not a bad idea to use a small collet on the shaft as a shaft / prop saver.
                            • Dashunde
                              • Sep 2014
                              • 53
                              So you know how some boats are just evil or doomed right? I got another 440/3 prop on it, ran it at the lake and it ran really good.. into a dock :/
                              I promptly ordered a new Smash Shark - cause I had it running good, the second one was $30 cheaper than the first, and I have all the upgrade parts for it already - the new one showed up today and I got all the good stuff swapped into the new hull, including marking/drilling the OSE 4-bolt rudder, in just a few hours.
                              This boat is already much more cooperative :)
                              I like the 3-blade, but its making my ESC wires pretty hot, I should probably go with bullet connectors but I use all of my 2s hard packs in my 1/8 scale buggies/trucks too, so I want to stick with the Deans.
                              What would be a step down from a 440/3? 440/2? Maybe a 442? or just detongue this 440/3 some more?
