Will R.E.K 3.5 outboard lower unit handle 6S power ?
  • Andris Golts
    • 508
    Hi all i have a Dunlap 30'' WOF tunnel hull with a REK 3.5 size composite lower unit set up at present with a AQ 2030 kv on 4S im interested in upgrading to a Leopard 1900 kv 3674 size motor bolted to the 3.5 REK lower unit using a .150 flex shaft on 6S. Would the lower unit and flex shaft handle this kind of power? Regards Andris Golts.
    • 7512
    I went through 5 flex shafts on that lower unit on 4S...good luck on 6!
      Short answer - no. That cable size is too small for an inboard setup with that much power, how will it last in a plastic lower?
      • Andris Golts
        • 508
        Thanks to both of you for your replies. Doby i have been using the REK 3.5 lower unit for the last ten years on 4s power probably had close to 200 runs on it and only snapped 1 flex shaft . Every 6 runs i remove the flex shaft wipe of old grease and re-grease using Mercury 2-4-C grease and twice a year when flex shaft is removed i spray brake cleaner through the brass liner to remove old grease and crud. Regards Andris Golts.
        • teamgear1973
          • Jun 2017
          • 68
          Hey bud I'm the process of building a tunnel. I was,wondering where you got your lower unit from?
          Sent from my SAMSUNG-SM-J120A using Tapatalk
          • Andris Golts
            • 508
            Hi Teamgear 1973 i bought the 2 REK lower units from Fullers fast electrics 10 years ago i destroyed the one lower unit hitting a submerged dead head a month ago . I have had a friend looking for one for me ever since. Let me know if you find a shop that still sells them . Regards Andris Golts.
