speed passion motor in a miss gieco 29
If it has a smooth can (boat) not like the heatsink can (car) in the link. 2700kv 6s?..Needs to be under about 2,800 watts for the stock ESC. Water jackets are funny in that one manufacturer will list their motor as a 40mm can but its actually 38-39.something so good luck with that. At that price point look up TPPowerUSA.<free jacket
There are so many other motors more suited for boats. You would need a custom cooler for it if HRC can make one.
there are 2 types of Castle Neu motor cans, the 15 size [ 40 mm ] has raised fins and the 14 size has indented fins. O.S.E. has the special cooling jacket to suit the 15 size motors and you can use just about any 14 size [ 36 mm ] cooling jacket. what i do with all cooling jackets to be on the safe side is after i fit the cooling jacket to motor i run a bead of silicon sealant around the edges to asure no leaks occur.
As above, stated that sensored motor is not a good choice for a 6S boat. The motor connections are not high-amp rated like more appropriate motors have and the Kv is far too high. The motor's "tons of power" will be converted to smoke and flames soon enough.
Save it for your truck and buy a more suitable motor, like a 36x74 size with a Kv between 1500-1800. The former for longer run times and less heat, the latter for speed with shorter run times.
