Vs1 tunnel
  • teamgear1973
    • Jun 2017
    • 68
    Vs1 tunnel
    Looking to see if anyone has turned the VS1 nitro into a electric tunnel. If so could you be kind enough to share how you did it and what all is needed to do so. Thanks for y'alls help.
    Sent from my SAMSUNG-SM-J120A using Tapatalk
  • JestDanny
    • Jan 2017
    • 176
    I have one on the bench now. Just mounted the outboard earlier this eve, all that's left is to make up steering cables , every thing is in place an benched tested. H2O testing starts next weekend. The biggest mod I did is the battery tray. I kept the steering servo an the rx in front box. I cut a recessed well in the center tunnel deck to lower battery to the floor of the tunnel, steering cables go over top of battery. ESC is where fuel tank should be. Very easy convert , took one weekend.
    PROBOAT BlackJack 24", ShockWave 26"
    MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint
    • teamgear1973
      • Jun 2017
      • 68
      Got any pics you wouldn't mind sharing of it bud
      • pescador
        • 499
        I have pics of my conversion build on photobucket
        A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
        Sent from my iPad using Tapatalk
        Namba District 16
        1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
        • teamgear1973
          • Jun 2017
          • 68
          Awesome bud. Thanks for sharing them
          • teamgear1973
            • Jun 2017
            • 68
            Pescador the steering cable that you are using in your boat are they the ones that come with the kit?
            • pescador
              • 499
              I used new cables and a belcrank arm but you could use the wheel and cables from the kit I think. I can't remember if the stock steering cables came with the plastic cover like the yellow throttle cable but the way the cables come thru the battery box I used the same plastic cover so the cables wouldn't rub the batteries. They are Dubro I think, easy to find at the hobby shop with the airplane stuff.
              Namba District 16
              • JestDanny
                • Jan 2017
                • 176
                I an going to run 3S buy a 4S will fit in my battery tray.
                • teamgear1973
                  • Jun 2017
                  • 68
                  Originally posted by JestDanny View Post
                  [ATTACH=CONFIG]152255[/ATTACH][ATTACH=CONFIG]152256[/ATTACH][ATTACH=CONFIG]152257[/ATTACH][ATTACH=CONFIG]152258[/ATTACH]
                  Thanks for sharing. Hope to start mine soon
                  • rol243
                    • Apr 2017
                    • 1038
                    guys, there used to be a good upgrade for the K & B outboard leg that many guys did . what you do is if your leg is fitted with a teflon shaft tube only you get rid of it and bend to shape the same length of brass tubing to use as the main shaft log. this eliminates any drag caused by the teflon / bend thus lets the motor run alot freer. also if your running the pull pull steering set up use fishing wire stainless trace, never breaks.
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 6958
                      I built several tunnels. The VS-1 was a fun build. (pictures from different builds)
                      just a few details:
                      I enclosed the whole interior
                      Most builders locate the servo up front using cables to steer. I preferred rear-mounted servo with 4-40 rods
                      Pass - through "tube farm" for 3 motor wires, two servo rods plus 2 cooling lines. I inset the motor mount to shorten the pivot length for crisper handling (not necessarily worth the effort)
                      continued
                      • properchopper
                        • 6958
                        Two of the builds: (same cowl)
                        Best to avoid "death buoys" ; can cause slight disassembly
                        • teamgear1973
                          • Jun 2017
                          • 68
                          Those are some nice builds guys. Thanks for sharing the build photos
                          • teamgear1973
                            • Jun 2017
                            • 68
                            Whoop whoop my VS1 should be here next week..
                            • teamgear1973
                              • Jun 2017
                              • 68
                              Hey what did you use to enclose where the battery goes?
