Leopard 3674 2200 KV 180 amp esc for JAE .21 prop dia + timing ?
  • Andris Golts
    • 508
    Hi all installing a Leopard 3674 2200 KV motor in my J.A.E .21 to run on 4s 5000 mah lipos .What diameter props can this motor swing safely with out melting down ? Which timing setting should i program on the esc 0 degrees or 3.75 degrees ? Regards Andris Golts.
  • rol243
    • Apr 2017
    • 1038
    a very good prop is the ABC / H7, i have the same set up kv motor and this prop works very well it was recommended by Zippkits jae 21/fe review build. as for timing set it at 7 degrees but you can go up to 15 degrees if you want abit more power.
    • Andris Golts
      • 508
      Hi rol243 thanks for your reply. Regards Andris Golts.
      • skiking1739
        • Jun 2009
        • 108
        I have a Turnigy 3674 2200kv I was thinking of doing the same thing with. Does anyone know if this motor is a D or Y wind, and what the timing would be. Its the XK-3674 Gray Motor.Thanks.
        • rol243
          • Apr 2017
          • 1038
          Hi, your motor is a D wind and a good safe timing is 7 degrees, you can go higher but just check motor heat after a short run. i just tried the Turnigy xk 3674 - 2200 kv purple motor and its very impressive .
          • skiking1739
            • Jun 2009
            • 108
            I have never run the purple motor, but the gray motor is pretty stout. Thanks for the info.
            • rol243
              • Apr 2017
              • 1038
              there have been reports that the new xk turnigy motors are copies of the leopard motor. not sure if this is true or false, just what i have heard.
