just bought an aeromarine avenger 36. the zelos 48 ended up being too big for me to handle physically. want to build this conquest a twin. I have (4) 5s 5000 batteries and would like to be able to use them whether its 5000 or 10,000 mah setups. i have 2 leopard 4082 1600kv with seaking 180's. i have 2 neu 1527 2300kv with castle 240's. which would be the better choice for a fun, reliable boat?
aeromarine conquest
more run time with the leopards? and would 10,000 mah be too much for this boat? if so, i will have 2 packs to switch off to for more uninterupted running. thanks.Originally posted by rol243 View Posti say the leopard / seaking set up if your just wanting a fun boat. your neu set up is a good race set up.
You would get more run time with the Leopards, those are both 4S setups but the high-Kv Neus will draw plenty of amps and may challenge the SK-180s. If you ran a single 4S2P setup supplying both motors the weight will be fine. If you want 4S2P to each motor, that is pretty heavy. The boat will handle it, but performance will be downgraded somewhat. A club member ran that hull on 10S2P/4000 packs and it was okay. It will be more difficult to blow over.
aeromarine avenger
hi fluid. i was hoping to run the hull on 5s2p to both motors. 2 neus or 2 leopards. will this work? the neu's are hooked up to castle 240's with cap banks. if i was to run them. i already have (4) revos 5s packs. 5000 mah. thanks fluidOriginally posted by Fluid View PostYou would get more run time with the Leopards, those are both 4S setups but the high-Kv Neus will draw plenty of amps and may challenge the SK-180s. If you ran a single 4S2P setup supplying both motors the weight will be fine. If you want 4S2P to each motor, that is pretty heavy. The boat will handle it, but performance will be downgraded somewhat. A club member ran that hull on 10S2P/4000 packs and it was okay. It will be more difficult to blow over.
you don,t really have to use 2 x motors for this hull, 1 neu motor would push this hull around quite well. if you want to go twin motors i would just use the leopards for a fun boat but if your going to race it use the twin neu,s. not a cheap boat using 2 x neu,s and 2 x 240 amp castle esc,s i must say.
This is the same hull that I race.
The 2 Leopard 4082 1600kv with Seaking 180's. is a good 5S setup.
The 2 Neu 1527 2300kv with castle 240's. is a 4S setup
There is No need to put 4- 5S-5000 packs in that hull (too much battery weight)
Two 5S packs, wire your ESC together so that each motor sees the 5S2P.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
my first twin. how do i wire the esc's together? and how do i handle bec. do I use a y-connector from bec to both recievers?Originally posted by TRUCKPULL View PostThis is the same hull that I race.
Larry
what is a good cg for this setup? thanksOriginally posted by TRUCKPULL View PostThis is the same hull that I race.
Larry
Wiring diagram for two ESC's - so that each motor sees your 2P setup.
You also put a plug in-between the ESC's on the black wire. This is done so you can disconnect the 2 ESC's from each other when you make any changes to the programing.
BEC - Disconnect the BEC from one of the ESC's, or both and use a U-BEC
The batteries go under the pool noddle down in the sponson.
CG - is 12 1/4" from the rear of the hull.
LarryLast edited by TRUCKPULL; 06-13-2017, 11:31 AM.Past NAMBA- P Mono -1 Mile Race Record holder
JohnOriginally posted by urbs00007 View Postmy first twin. how do i wire the esc's together? and how do i handle bec. do I use a y-connector from bec to both receiver's?
Only one Receiver is required.
aeromarine avenger
thanks for your help. so the way the esc's are wired, they get 5s 10,000 mah? if so, thats great. also, are the batteries strapped in. if so, are the pool noodles just added restraint? one more if you dont mind. are you running conventional struts?Originally posted by TRUCKPULL View PostWiring diagram for two ESC's - so that each motor sees your 2P setup.
Larry
Both ESC's see 5S - 10,000Originally posted by urbs00007 View Postthanks for your help. so the way the esc's are wired, they get 5s 10,000 mah? if so, thats great. also, are the batteries strapped in. if so, are the pool noodles just added restraint? one more if you dont mind. are you running conventional struts?
Batteries are held in with Velcro , the pool noodle helps hold it in place.
Struts - https://www.offshoreelectrics.com/pr...os-stinger-str
