How to tune stepped mono for racing?
  • Jesse J
    scale FE enthusiast
    • 7818
    #61
    Thanks Paul. I think I saw you faffing around in there... but it was high speed faffing!
    I had glued a bracket I made into the groove on the far starboard just before I saw your post...
    then I ran down, pulled out the bracket, wiped off all the glue and cut through the hull along that groove. I slopped a bunch of glue into the groove and then pushed the bracket down into the groove.
    Thanks for posting the vid, it got me visualizing that mount popping out since it wasn't anchored into the hull.
    I'll post a pic once it's cured up.
    "Look good doin' it"
    See the fleet
    • Jesse J
      scale FE enthusiast
      • 7818
      #62
      Gotter licked!
      See the fleet
      • CornelP
        • 793
        #63
        Hi Jesse,
        I do not know if you are aware of this:
        some of the best resource for H&M boats...
        On mine, I ended up with an oval turnfin that was touching the water a lot less and it was ok.
        • Jesse J
          scale FE enthusiast
          • 7818
          #64
          Hi Cornel, thanks for the link... but it's not working?
          See the fleet
          • NativePaul
            Greased Weasel
            • 2770
            #65
            It works for me, are you at work, if so try from home as IT may have blocked galleries.
            Interestingly they show one with an angled out fin, one with a vertical fin and one that looks like it has an angled in fin.
            The camo boat looks like it is one of Bernd Weiss's from the colour scheme so I would follow that setup as his boats always rip, but they don't show the fin on that one.
            • Jesse J
              scale FE enthusiast
              • 7818
              #66
              not at work, on mac and ipad - no worky for me...
              BUT, I did make this today.
              I was able to get 3 and a half minutes on 3300 mah, and all electrics below 110F.
              pretty happy with first results. Now if I can get this thing to self right in under 2 minutes...
              See the fleet
              • Jesse J
                scale FE enthusiast
                • 7818
                #67
                link doesn't even work on my PC... wonder if its a US vs Euro thing?
                See the fleet
                • NativePaul
                  Greased Weasel
                  • 2770
                  #68
                  Could be I suppose, i dont know why H&M would restrict their content though as they are trying to sell workldwide. Try this one, it goes to the gallery instead of the slideshow, so it may be simpler for your browser to process.
                  • CraigP
                    • May 2017
                    • 1464
                    #69
                    The link worked for me, I'm in the States... Nice pics!
                    • Jesse J
                      scale FE enthusiast
                      • 7818
                      #70
                      Even when I go to the hydromarine.de site and navigate to this page: https://hydromarine.de/shop_content....dkes95dc8m09g4 - it doesn't load... Firefox nor chrome on mac... not IE On pc !?!?
                      See the fleet
                      • Jesse J
                        scale FE enthusiast
                        • 7818
                        #71
                        Tried again.. but man it runs like crap now: https://youtu.be/uQ3SCami-fI
                        so I propped up to a 40mm, then back down to 38mm and both made it behave like an idiot.
                        I will need to move the ESC back behind the motor and add ballast to get the CG behind 33%
                        do you think the prop needs to be higher? the prop closer to the transom? it sure aint fun driving it like this...
                        See the fleet
                        • CraigP
                          • May 2017
                          • 1464
                          #72
                          Jesse, I see just one turn fin, on the starboard side. It looks like it’s running in the water while going straight. On my Mono, it’s real important to have balance, both in weight and drag components. I have two turn fins on the back, both are set high enough so that they don’t get wet going straight. Have you tried a setup like that?
                          BTW, is the self fighting using a flood chamber or outrunner motor? I like that!
                          • rol243
                            • Apr 2017
                            • 1038
                            #73
                            normally the port side turn fin is only needed if your going to be turning left abit. if the hull performs well with only 1 x starboard fin fitted than leave it at that, saves on extra drag as well. looks like alot of rudder throw too. [ drop it down ]
                            • CornelP
                              • 793
                              #74
                              Jesse, I ended up using a 35mm prop on mine, running around 37000rpm and it was quite ok. Another guy here used a 3 blade 36 and it was a lot more stable.
                              Try a smaller turnfin or angle it a bit. No need for a second one on a stepped hull, it's just extra drag.
                              • Jesse J
                                scale FE enthusiast
                                • 7818
                                #75
                                Ok, I'll prop down and try again.
                                I was going off Paul's comment that speeds looked low and that other naviga racers are using 40 mm props.
                                See the fleet
