modified TFL Princess Yacht
  • Newboater
    • 359
    Okay so I have two speed boats and a Tug, figured I would shoot for the middle with a boat that does 35-42mph on 4s, and can be used in rougher water.
    First thing was to remove the strut drill it out with a 1/4" drill and insert a 3/16 speed master bushing so the standard flex cables could be used. Next was to install the Leopard 4074 1650 KV motor and raider 150 amp ESC. The boats factory motor mount was pretty close but I had to remove the 36mm rear support and dremel it out to 40mm. Next was to slightly open up the rear mount holes that hold in the rear support. Only needed to remove about 1/8" material. Next was to remove the wooden center battery tray and install the ESC mount and then put in two carbon fiber battery trays toward the rear of the boat, to help try and get close to the 30% cog. Finally the last step was to add a longer rear rudder a 645 prop and floatation to the front and rear canopy's with a bungy latch system incase of an unforeseen event.
  • Newboater
    • 359
    additional pictures
    • zooma
      Local club FE racer
      • May 2014
      • 653
      I will be interested in your progress. I put in the SSS 3074 2074kv. I also switched to a 1.5 flex shaft, but just changed the bearings in the stinger. Running a ProBoat 4019 prop (which would be like a 640 Octura). 120 AMP Aquastar ESC. Due to hooking and spinning-out, I have installed the longer rudder and turn fins, for some improvement. Moved the CG back by mounting the 4 cell pack accross the stern, in front of the servo mount. With this setup, I am getting only 28 MPH. But it still hooks and flips sometimes.
      I would like to cure this and get some extra speed.
      I'd like to know how you drilled out the stinger and what sleeve you used.
      Be aware that the hatch hold-down (cabinet latch) won't stand up to a flip. I run some hockey tape from one side, over the cabin top, and down to the other side.
      Ron - The Villages, FL
      • Newboater
        • 359
        I drilled out the stinger with a 1/4" drill bit and installed Speedmaster Bushing 3/16" for Stinger, ose Product ID: ros-spdsd-187. I believe the bungy set-up with the catches will hold okay if I flip but won't know till it happens. How did you mount the battery in front of the servo it doesn't interfere with the collet drive? I would think you would want to keep the weight as low in the hull as possible. I will try and run the boat this week if it stops raining and will let you know how it performs and will GPS it. Who knows may run like crap as I really have no idea what I am doing I tried too mount the battery trays as far back and to the sides for stability. I also added 2 ounce fiberglass throughout the hull and sides so the boat is heavier then stock so this may add to the stability.
        • zooma
          Local club FE racer
          • May 2014
          • 653
          ///// double post
          • zooma
            Local club FE racer
            • May 2014
            • 653
            The battery bridges across the hull, above the stuffing tube. I use Velcro patches on each side of the hull.
            Here's a video. Looks faster than the GPS says.
            Where are you in NY?
            • Newboater
              • 359
              I am out on Long Island NY but I own land in Beverly Hills Florida in the Pine Ridge Estates. My wife has one more year until she retires and we head down. Which villages are you in? I understand there are several of the Village communities throughout Florida.
              • zooma
                Local club FE racer
                • May 2014
                • 653
                There is only one "The Villages" community that is associated with this developer. 60 miles north of Orlando and 20 miles south of Ocala. Started as a mobile home park 25 years ago. Now a major retirement golfing community of about 55,000 homes, and still growing.
                I'm a LI native, and used to watch the nitro boats at Artist Lake. I understand that there is a group at Eisenhower park in Nassau county.
                • Newboater
                  • 359
                  I am out in Wading River, and go to Artist lake. They don't allow the gas boats anymore only electric. Never been to Eisenhower park. According to the map you are directly across from Pine Ridge Estates. Going to run the TFL tomorrow so will have some information for you. My wife though there was several Village locations, I thought there was only one. It is where everything is contained and a lot of people own golf carts to get around right?
                  • zooma
                    Local club FE racer
                    • May 2014
                    • 653
                    Well, it's only you and me on the thread, so I don't feel like I am hijacking the topic. Beverly Hills is across the state, but about 40 miles away. Inside "The Villages" there are about 50 named villages. About 500-1000 homes per village. Three "town squares" with stores, restaurants, and daily live music. Yeah, people get around in golf carts. Tons of clubs, golf courses, recreation centers, and pools. We have about 60 guys in the fast electric boat club. We run for fun and practice twice a week on a small local lake. Race twice a month on a bigger lake in the next town outside The Villages.
                    Now back to our topic. Even near 30 MPH, this boat gets a lot of attention. But, the average FE hull in the club is going around 35-45, and that's my goal. I use a Garmin Forerunner 201 GPS. I also have hotter motors and ESCs to try, but right now handling has been holding me back. I do have another even longer rudder on a longer bracket (left over from a Pursuit) to try. Good luck, and keep us informed.
                    • zooma
                      Local club FE racer
                      • May 2014
                      • 653
                      Good grief, I just found this video:
                      • Newboater
                        • 359
                        Took the TFL princess for the first run. The water was choppy with 15 mph winds. It was leaking around the water jacket filling the hull with water so we had to cut the run short. The GPS said she ran 32mph But the boat was running way too wet. I am going to fix the water jacket tonight. Going back tomorrow and will make adjustments to the battery position and strut to see what the top speed will be. The leopard 4074 at 1650 kv on 4s is turning low rpm's so I May need to swing a bigger prop.
                        • zooma
                          Local club FE racer
                          • May 2014
                          • 653
                          Yes, a low KV motor like that needs either higher voltage or a bigger wheel. And, If you can trim it to be more loose, it should get up to 40ish MPH. Now I'm getting motivated to get my Princess out and give it a few tweaks.
                          • Tamelesstgr
                            • Jun 2014
                            • 1512
                            You've got good gap between the drive dog and stinger, is that prop sharpened and balanced? It looks rather dull and blunt perhaps that is an issue not having the speed you want.
                            NEVER SATISFIED RACING
                            Fine Design 32 V-Hull 4082+6s
                            • Newboater
                              • 359
                              That wasn't the prop I ran but all of my props are sharpened and balanced that one is sharp and balanced but was used last year.
