HPR C5009 bouncing - help
  • Amisol
    • Jun 2016
    • 70
    Hi,
    My setup is:
    HPR C5009
    2 x leopard 4082 2000kv
    2 x seaking 180a v3
    2 x cnc 44mm props (pitch 1.4)
    2 x gens ace 6s 5000 mah 60c
    The hull bounces a lot. I've lowered the stingers, and it got better 10 percent. But still a lot bouncing. The left motor is set to run left, and right motor runs right. Any suggestions?
    Videolink of bouncing: https://m.youtube.com/watch?v=IB5uJKyN3W4
    Here are some pictures of the inside of the hull. And the stingers are lowered, the batteres are placed as front as possible:
    Thanks for replies :)
    • 4340
    Where is your center of gravity with the batteries as they are? Also, your left motor cooling lines are plumbed backwards.
      Mmm, I am going to say possibly transom lift. But these hulls have rude characteristics till they are up to speed.
      What kind of angle is on the stingers?
      I just looked at your pics. I would first try swapping the props/cables over. And of course changing motor directions. I have not seen anyone run these with outward spinning props, only inward.
      Shawn
      • Prodrvr
        • Jul 2015
        • 701
        Raise the stingers, it looks like there's too much negative trim. Bring them to level with the sponsons, then test again.
        • Amisol
          • Jun 2016
          • 70
          Thanks, guys :)
          Will try to do some changes.
          • numse
            • Jan 2017
            • 7
            Hi
            Good working Center of gravity is around 29,5 cm from the start of the transom.
            • Amisol
              • Jun 2016
              • 70
              Now the hull is working fine, no bouncing. Thanks for the replies. I had to switch the rotation - now i have inwards. Here's a short drone video of the boat: https://www.youtube.com/watch?v=ln-Cubt453U
              • Bradb74
                • Sep 2017
                • 86
                Hi,
                I'm putting together the same boat, how fast is yours with this setup?
                Thanks,
                Brad
                • Amisol
                  • Jun 2016
                  • 70
                  Approx 76.5 mph. https://m.youtube.com/watch?v=ln-Cubt453U
                  • Bradb74
                    • Sep 2017
                    • 86
                    Awesome, thanks
                    • Nikolas Andriop
                      • Jun 2015
                      • 73
                      With this setup you sould use at least X447mm props
                      • jeff351
                        • Jul 2017
                        • 10
                        That drone video is really slick!
