Originally posted by Newboater
View Post
Artist lake, middle island NY
I'll consider that. I only have 4 and 6 cell packs, but the 6 cell 5000's weigh a ton. Is that what you are using, or two 3S? I also have the original 1620 kv motor. It's a good kv for 6 cells, but might be weak on high amps. Anyway, I can't get out for a week or so.
I am running two 3s packs SMC 7200mah that are over a pound each. I have them mounted left and right side of the motorAttached Files
Oh you wont use that again If Steve has aeromarine cables , I use them !!!Originally posted by fweasel View PostNo, cheap original Proboat cable. I think they're crimped, no soldered. Replacing with a wire drive, but still deciding on the replacement prop which is why I'm interested in Newboater's run.
Are you going to set that up for electric or leave in nitroOriginally posted by Bigford View Post
I'll run the boat this weekend 6/4. I have two different props to try will GPS both and have results, unless I snap a cable also....Originally posted by fweasel View PostNo, cheap original Proboat cable. I think they're crimped, no soldered. Replacing with a wire drive, but still deciding on the replacement prop which is why I'm interested in Newboater's run.
Cool. Good luck. You're running the Voracity 1650kv motor, right? I've got a spare one of those, maybe I'll switch over to that as well.Originally posted by Newboater View PostI'll run the boat this weekend 6/4. I have two different props to try will GPS both and have results, unless I snap a cable also....Vac-U-Tug Jr (13mph)
