How to Open a Pro-Boat 1500Kv Motor
  • Ken Haines
    Racer
    • Jul 2007
    • 673
    Does anyone know how to open a Pro Boat 1500Kv Motor.
    Sounds like I have a bad bearing in one that needs replacing.
    I have an old burnt 1500, but when I looked at them today
    I am really not sure how they come apart.
    Looks like the endbells may be threaded, but I am not sure.
    Thx,
    Ken
    TenShock Brushless / Pro Marine
    INSANE Boats / Rico Racing/ Castle Creations
    2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
  • RandyatBBY
    • 3943
    If there is no screws they are glued. I just tap on the shaft while holding firm and the end bell pops off. Then I use CA to glue back on.
    Randy
    BBY Racing
      If you don't mind me asking Ken, how do you tell or what signs do you see that can indicate a bad bearing while motors is still assembled?
      Usually I can only tell once it's apart.
      • RandyatBBY
        • 3943
        The bearing will make noise or move a little sideways.
        Randy
        BBY Racing
          Note that if you remove the endbell by tapping on the shaft you will flatspot the balls and/or dent the races in the endbell bearing. It will need to be replaced regardless if its condition prior to removing the endbell.
          • Ken Haines
            Racer
            • Jul 2007
            • 673
            This motor is making a very odd sound when running in the boat.
            It also has an odd faint metal sound when simply turning the motor by hand.
            Could be a rotor rub, but I suspect just a bearing. Either way it needs
            to come apart to try to figure it out. I hate to just pitch it even though
            these motors are relatively inexpensive.
            • Ken Haines
              Racer
              • Jul 2007
              • 673
              I will assume the endbell only opens at the lead wire end like the AQ motors ?
              I only ask as the recent Neu and TP motors open on both ends.
                Most likely. I know AQ gold motors are threaded and glued up front.
                  Thanks buddy. I recently dropped a motor on it's shaft and it pushed out the endbell. I better order some bearings.
                  • 785boats
                    Wet Track Racing
                    • 3423
                    Ken.
                    It is not the rear endbell that you remove. It is the front endbell. It unscrews.
                    One bearing has a flange on it & the other one doesn't.
                    Pay attention to which end each bearing goes & please let me know.
                    I pulled one apart ages ago & have forgotten. It is still in pieces.
                    Also could you let me know where you get the bearing set from as I haven't been able to find them.
                    Thanks.
                    Paul.
                    • Ken Haines
                      Racer
                      • Jul 2007
                      • 673
                      Ken.
                      Thanks.
                      Paul.
                      Hi Paul,
                      I had already tried tapping the shaft on the burnt motor
                      and the shaft moved inside the rotor.
                      If you are correct I may need to build a little make shift jig to
                      safely enable me to unscrew the outboard endbell plate.
                      I am leaving soon and will give it a try tomorrow and let you know.
                      Thx,
                      Ken
                      • Hydrocarbon82
                        • Apr 2016
                        • 68
                        The shaft will turn with more effort, sometimes lots of effort. The bearing will be "crunchy", or not smooth when turned, or simply seized up. My proboat 3650 had a seized bearing on the output shaft side. It made no noise but was very stiff, still ran okay. To be fair with Proboat, the boat had been fully submerged multiple times all summer, lol.
                        You can usually find the bearings on ebay (they use generic size), just don't go too cheap. Some china bearings are utter crap.
                        • T.S.Davis
                          • 6266
                          Ken, keep in mind that if you repair the motor with new bearings it's no longer legal for NAMBA competition. Works up here and in Atlanta but if you trek to Vegas you're screwed.
                          Noisy person
                          • Ken Haines
                            Racer
                            • Jul 2007
                            • 673
                            Hey Terry,
                            Still can't get the rubix cube to open,
                            but if I do I was simply planning to use the bearings from another
                            pro-boat motor that gave up last fall. Pretty sure that is legal,
                            but if not I will just simply chuck both of them.
                            Btw....all 19 boats are ready and loaded ready for the trip to Atlanta.
                            • T.S.Davis
                              • 6266
                              Ours aren't loaded but there are 21 of them. I have 3 more props to do tonight.
                              Noisy person
