Batteries no long have a punch
  • millzrm
    • 26
    I have several cheaper quality batteries that have gone several months (+6) w/o use and now when I charge them they just dont have the same perfermance as they use to. This is the case whether I use them in my RC Boat or Truck.
    Questions:
    Is there anything I can do?
    Recharge them again?
    Will running the batteries totally dead and re-charging them help?
    Should I just buy new batteries?
    Is there anything you can do to prolong the life of the batteries in-between seasonal use?
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    What type of battery chemistry? What charge level were the batteries stored with? Were the batteries subject to high temperature discharge levels?
    Douggie
    • millzrm
      • 26
      I'm not sure what you mean by chemistry - can you elaborate?
      The batteries affected are 3 different brands/kinds, ranging from 3000mah - 3600mah. They were most likely used and put away for the season (no discharging). I wouldn't say the batteries were discharged at high levels. The setups in both my boat and truck are more novice, I am not trying to break speed records with either toy.
        • 7512
        Chemistry = LiPo, ,,,NiMh,,,, NiCd.....etc
        If they were NiMh as I suspect, then you might need to charge and discharge them at a low rate (around .5 amp) for about 5 cycles. They might come back to life.
        • Spot Me 2
          • 770
          If they were Lipos, You should have stored them at half charge.
          MMGMMarine
          RobertsonRacing
          • JimClark
            • 5913
            If they are NIMH take a reading off of each cell with a meter to see if you might have bad cells.
            Jim
            Billy Graham
