J.A.E. .21 FE set up with Leopard 3674 2200 KV motor ?
  • Andris Golts
    • 508
    Hi all i have a JAE .21 FE im installing a Leopard 3674 2200 KV motor on 4s power . I have a Seaking 120 amp esc is this enough amp rating ? What size prop should i be using ? What kind of speed should i be getting? Regards Andris Golts.
  • grsboats
    • 1011
    Hi Andris this set up is partially ok for your Jae. A 120esc for this motor in my opinion is ok for short runs but I would sitck to a 150 or 180A to be on the safe side depending on props.Octura 1450 reduced to 46mm is a good prop and expect 60's and more with no problems.Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • FORT-26
      • Apr 2014
      • 239
      I'm building one with the same motor now...I'm running a SK180....I don't trust the 120, because of voltage spikes. The SK180 has a spike rating of over 1,000Amps I believe.
      I'll share my experience, once I get it finished. It's about 90% complete. I'm pretty excited. It should RIP! There's a real good video on the TUBE of a JAEFE with same motor.
      -Chad
      • grsboats
        • 1011
        Chad The SK 180 is overrated at 1000A......consider it just 360 like the previous version and expect higher temps compared with the older but it works good.Gill
        www.grsboats.com.br
