Phil Thomas sport 45
  • Shooter
    Team Mojo
    • Jun 2009
    • 2751
    Hi Mark. I ran my smaller PT boat with the rudder on the right side. I didn't have anything to compare it to, but it ran and raced well. The servo 'pulled' when turning right (rudder link was towards the outside of the boat). I remember Randy telling me this was a good practice. If it pushes to turn right you risk more flex in the system.
    Here is a vid (not a race, but good enough for reference):
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      I had a SS45 as well, but I ran the rudder on the left....
      http://forums.offshoreelectrics.com/...S45&highlight=
        Stop sanding so much. Start with the spackle and wipe off with a barely damp sponge. Repeat. Each deeper sanding makes more holes.
        Thank you!!
        I was just going to put some finishing epoxy on the inside (of the cowls) so it would pass through the little voids into pin holes. Some pin holes go through to the inside.
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 988
          I did the epoxy on my cowl too. Well after 2 days at my buddies house, he had some white and dark blue PPG epoxy paint left over that I could have, I got the boat painted. He did the spraying and I did all the prep and taping work. I think it came out pretty good.
          Mark
            ....I think it came out pretty good...
            I think so too!
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 988
              Now if I could just decide on the left or the right side for the rudder:)
              Mark
                • MarkF
                  dinogylipos.com
                  • Mar 2008
                  • 988
                  I know. It looks like no one has built one of these recently. I put the rudder on the right of all my hydros and think I should just go for it on this one. If you were building one of these Jay, would you go right side?
                  Mark
                  • longballlumber
                    • 3417
                    When I still owned the boat I had decent success with the rudder on the left.
                    Although this was a time trial event, I was running my heat racing setup - https://youtu.be/NRoMLxtbY4Y
                    Here is how it handled in race water - https://youtu.be/Li_KTBHzz2E
                      Threading a needle nicely Mike
                      • MarkF
                        dinogylipos.com
                        • Mar 2008
                        • 988
                        Very nice Mike. What your motor setup? Whenever I have played with putting rudders on the left of my hydros in the past, I always came back to putting them back on the right side. That's why my hesitation, but you guys all make the boat look good with it on the left. Also do you like the tapered rudder or is a 1" strait going to work fine?
                        Mark
                          My buddy Steve Muck says that in his experience (rather substantial) a straight rudder works best on most Sport 40 boats. I have seen minor benefits over tapered rudders, especially in rougher race water.
                          In spite of the success of left rudders on this hull, I'd try it on the right myself. This assumes a good-sized hooked turn fin is firmly mounted.
                          • longballlumber
                            • 3417
                            Mark
                            NEU 1527 1Y
                            GrimRracer cells (8400mAh)
                            Octura X455 (bent up a bit)
                            If I remember correctly I had the speedmaster 21 rudder assay on there and that was a tapered blade
                            • MarkF
                              dinogylipos.com
                              • Mar 2008
                              • 988
                              Thanks for all the help guys. I am going with my first instinct to put the rudder on the right. Here is my turn fin and bracket. The fin is from ML boat works and one of the nicest SS turn fins I have seen. O flex on this setup.
                              Mark
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2751
                                That's a great fin. Kevin really knows what he's doing. Not sure if he's changed anything, but the first ones were based on the fin I made for the Black Pearl boat. I gained a consistent 2-3 mph when I switched to his thinner SS welded version.
