Best mono in class
  • kburrows
    • Mar 2008
    • 694
    Best mono in class
    Which is the best all around performance hull for stability,fun, and speed.
    The 25"-29" class with 12cells nimhs weight.
    SV 27
    Skunk work deep vee
    Delta force
    ebay knockoff DF
    Fullers hulls
    BBY monos
    h&m No step
    whats the similarities and differences and which could handle the best race chop and recover. Straight line performer but can handle quick turns and quick planeing.
    suggestions would be good and some vets. advise on thes hulls will be good. thx
  • Diegoboy
    • Mar 2007
    • 7443
    You forgot the Aeromarine Mini xXx.
    • dirtysouth31
      • 546
      sell him yours diego you are never gonna run it
      • egneg
        • 4759
        He would take a beating as that paint job cost a pretty penny!
        IMPBA 20481S D-12
        • Boatman
          • 875
          D.F. 29" with flood chamber in my opinin. plenty of room for big motor and cells. Can be powere low or high voltage combo. Class legal hull. Plenty of hardware and props for less expensive set up.
          • Jimmy Sterling
            • Apr 2008
            • 417
            I run an Oval Master 26 in our clubs 12 cell restricted class and it runs great but stands no chance against another club members NS2.
            Its faster then mine in the straights and turns like its on rails.
            I'd rather go with the NS2 over the Delta
            Come to the FASST side
            • rockwerks
              • 772
              Ns2????????????
              an RC rock crawler lost in a sea of boat parts.........
              • Jimmy Sterling
                • Apr 2008
                • 417
                H&M No Step 2
                • Norman2
                  • Sep 2008
                  • 354
                  Best Mono In Class
                  I would suggest a Aero Marine Laminates Titan 29. Has a 10" beam and
                  carbon fiber layer on the floor.
                  Norman2
                  34" Ekos Cat UL-1 Powered
                  • Norman2
                    • Sep 2008
                    • 354
                    Best Mono In Class
                    carbon fiber layer on the floor. It is Also Fiberglass not ABS like the Oval Master.
                    Norman2
                    • tylerm
                      • 310
                      Ain't gonna get much better than a DF29 or the skunkworks 29. I have the latter and its awsome, very similar to the delta.
                      • mike martin
                        • 357
                        Rico 29" will handle more chop than any of them . I've seen one with a 1515 1y in a one mile race walk away from 2 45" gas boats
                        • kburrows
                          • Mar 2008
                          • 694
                          Norman2
                          with that type of beam wouldnt you get a allot more drag, i guess it will be supper stable but me 10". wel question are titans only rigged with this trasmition part or can you do a direct flex drive, second what does a tranny really do for this hull, i noticed it really common for this hull.
                          • kburrows
                            • Mar 2008
                            • 694
                            Do you have video of this boat running, and what setup did you use. thx
                            • knpc
                              • 649
                              If anything it may have less drag at least it seems to with mine. The air seems to get under it more because of how wide it is. Mine seems to want to blow over once it gets into the mid 40s, but that may just be the way I have it set up. I run mine with a direct drive. I had a 9xl for a while, now I run it with an SV power system in it. It does 40 mph with the sv system and is stable at that speed.
                              Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
