Has anyone considered this?
  • SJFE
    • 4867
    Ok so it's only 110 amps...But man look @ the volts!!!!!!
    CC Phoenix HV-110 Brushless Motor Control
    Volts w/BEC No BEC
    Volts NO BEC 50 MAX
    Lipo Cells w/BEC No BEC
    Lipo Cells NO BEC 12S MAX
    NiCad or NiMh Cells w/BEC No BEC
    NiCad or NiMh Cells NO BEC 36 MAX
    BEC None (dual opto-coupled)
    Continuous 110 amps
    Minimum Cells 12 cells NiMH/NiCad or 4s LiPo
    Switching Rate Programmable
    (13, 26, or 52KHz)
    Resistance 0.001 ohms
    Brake Programmable
    Reversible Yes - change any two wires
    Low Voltage
    Cut-off Programmable
    Size 1.55 x 2.8 x 1.25"
    Weight
    (w/wires) 5.3 oz. (150g)
  • avengersteve
    • 395
    did i read that right 50 Volts!!!
    restoring the collection
    • SJFE
      • 4867
      Yeah you did!! Man I can water cool that so easy. Same price as the hydra.
      • Eyekandyboats
        • 1935
        some people have run these in boats
        larger boats like the Q,S and T i believe with good results. I was also informed you need a pistix as well.
        I am hopeing to set up a T mono hull and thinking of this. or the tired and true 40,160
        EYEKANDYGRAPHICS
        www.rclipos.com
        • lferguson
          • 227
          Yea, they have been used with get success in conjunction with Andys PiStix. Look at the "Falcon Reborn" thread on RRR. Sweet build and uses the HV.
          • SJFE
            • 4867
            I figured as much. Good to know. I think when I invest in a high end esc this one will be close to the top of my list:).
            • part time
              • 154
              here is a even bigger esc jeti spin 200 Dimensions: 63 x 120 x 27 mm
              Weight: 270 g
              Nominal current : 200 A
              Quiescent current:
              1,4 mA
              Accu NiXX / LiXX: 24-40 / 6-14
              Operating voltage: 18-59V
              Resistance in conducting state: 2x0,75 mΩ
              Number of power transistors: 30
              Cable cross - section (input / output: 2x4/4 mm2
              Input capacitance: 2x820 μF
              • SJFE
                • 4867
                Is it under 300?
                • lferguson
                  • 227
                  I think the Jeti spins are like buying Schulze in price and quality.. And I think UnitedHobbies carries them suprizingly enough. The 110HV's are very very nice.
                  • SJFE
                    • 4867
                    Yes I have seen the jeti units @ United. It's a tuff call between the 240 amps on the hydra or the 50 volts on the HV.
