Cool - Warm - Hot - Whaaaat?
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Metal is more thermally conductive than wood, if you are somewhere hot and that ambient temperature is above blood temperature, the metal piece will feel warmer than the wood instead of cooler, you are just getting a more accurate feel for the temperature. Luckily I have no wooden motors, so it is not an issue for me.
    Sound advice there Tony, and I love that odour meter, I didn't know such a thing existed, but I bet a burned ESC would read over 9000.
    Paul,
    You're correctly describing emissivity
    which is "the measure of an object's ability to emit infrared energy. Emitted energy indicates the temperature of the object. Emissivity can have a value from 0 (shiny mirror) to 1.0 (blackbody). Most organic, painted, or oxidized surfaces have emissivity values close to 0.95." [from Raytec site]
    Interestingly enough the Infrared temp sensor that Jay pointed out in in post #1 does have a setting to compensate for surface emissivity whilst my high buck temp guns don't.
    • zooma
      Local club FE racer
      • May 2014
      • 653
      Just my rule of thumb.
      100-120 F is cool
      120-135 is warm
      135-145 is hot
      145-155 is too hot
      155+ is burnt
      Ron - The Villages, FL
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        Yep. Conductivity. I like to think of it like this..... the metal object is pulling the heat out of your hand quicker, hence it feels colder.
          Lmao!
          • Keagan-Z06
            • Mar 2016
            • 970
            Gots to get me a temp gun now I presume.
            • TheShaughnessy
              • 1461
              Originally posted by Shooter View Post
              Ask a group of people to feel a 'piece of wood' and a 'piece of metal', both at room temperature. 90% of them will tell you the piece of metal is cooler. 20% will insist it is cooler even after you've measured the temperature.
              question one on my lab last week was exactly as you ask lol. The lab had to do with the specific heat of different materials (metals in this case). But why does the piece of metal "feel" cooler? That was also on there. Thermal*!***!***!***!**namics as one professor affectionately calls it. It has taken a lot not to ask about the rate of water flow and if more flow is better or worse for cooling. I've devised a gedankenexperiment to answer the question, but haven't moved to the real world yet.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                I think that's where I got the idea.......from a heat transfer class! That cooling question is interesting.
                • bob horowitz
                  • Apr 2016
                  • 259
                  I've always wondered about that. How does flow rate affect cooling rate. Do you need more dwell? time for more effective cooling. I have a number of machines in my shop that have heat exchangers, mostly water used to cool gases. I've always wondered, never did the research.
                  Bob
                    I actually did the experiment - but the Internet experts "knew better" and refused to believe the results. I encourage others to test for themselves....but remember that experiment results are only as good as the experimental method used....garbage in, garbage out.
                    • bob horowitz
                      • Apr 2016
                      • 259
                      Fluid,
                      So what were the results, and what were the parameters? I'm really curious.
                      Bob
