Your recommendations for a prop please
  • runzwithsizorz
    • Jan 2009
    • 901
    Need to order some o-rings from Steven, but feel compelled to add something more to my order. The only thing I think I could use right now,(and can afford), would be a 3 blade prop for the big Sniper I am building now. It has a TP 5670 1180kv motor on 8s 2p, 1/4" flex reduced to a 3/16" shaft. Have plenty of 2 blades to try, but NO 3 blades. This is my first big boat. Nothing to drastic mind you, just a 3 blade ya'll feel would work as a good starting point. Thankz in advance for your input. Based on your input I will order tomorrow. EDIT, I do have 3 blade props, but they are all 45mm, and less.
  • photohoward1
    • 1781
    Depending the controller a 455 or even a 457 could have that thing hauling the mail. (do they still haul mail?) What controller because you better have at least a 300 to run a big prop.
    • runzwithsizorz
      • Jan 2009
      • 901
      Oh goodness forgot to add that, the ESC is a custom modded by ben 300amp fighercat with large dual cooling plates, and 2 water pick-ups.
