Hydro&Marine T4 1/10
  • gabz17
    • Jan 2017
    • 24
    Than you so much Ray for all your help. I truly appreciate it. I still haven't found bill but I found little info going through my emails with Chris @ Fine Design. In the quote given " 8S Level for speed And Can go to 12S if need be, with The ESC Castle Ice 200HV . A New Futaba Rec. Are 4.66 HP Nemesis Gold Motor, All HW Prop, Wing Asm. Water proof Servo, metal SBP Prop.100% Rtr.
    Sent from my SM-N920W8 using Tapatalk
      You will still need to know for certain what the motor Kv is. The quote given sounds generic, not specific to your build. Just slide off the water jacket or contact Chris and find out for sure, otherwise as stated above you could have big problems including burning up your electronics with the wrong voltage/prop.
      • gabz17
        • Jan 2017
        • 24
        I took a closer look around motor and I see 1000 marked with a sharpie.
        • gabz17
          • Jan 2017
          • 24
          Found receipt and its 1000kv
            • 7512
            #35
            Then its an 8S motor....so your batteries get connected in series.
            • gabz17
              • Jan 2017
              • 24
              #36
              Thank you so much Doby. Here are pics of out going plugs from boat male and female. I wanted to know why in Lipo the male plug is covered with yellow shrink wrap? Is it just to protect it when shipping?
              • stratus
                • Dec 2016
                • 110
                #37
                its to protect so the 2 cables not come in contact to each other,that would be bad
                Genesis 36", Zelos Twin 36"
                  • 7512
                  #38
                  That would be bad....
                  Are you familiar with series connections?
                    You could add extra heat shrink to the female. if you do 4 or 5 layers and overhang it a little after the second layer it will make it much safer.
                    *There will be a VERY big spark when you connect batteries. Either be ready for it or use a spark suppressor. A 30Ohm, 1/2 watt resistor works.
                    • stratus
                      • Dec 2016
                      • 110
                      #40
                      yes iam,whats your point?
                      • gabz17
                        • Jan 2017
                        • 24
                        #41
                        I think he was asking me
                          • 7512
                          #42
                          Not talking to you.
                            • 7512
                            #43
                            Yup.
                            • gabz17
                              • Jan 2017
                              • 24
                              #44
                              Yup.
                              No clue, except what I can find on YouTube.
                                • 7512
                                #45
                                this is about a simple as it gets...
