Hi , new to boats and looking to build an MHZ Cougar wharf boat 51" ie 70" fountain
  • devin120
    • Jan 2017
    • 2
    Hi,
    So I originally fell in love with cats. I got two 400a 16S escs expecting to do a 1000 kmh with ease. Clearly. No.
    Looking around, I decided a mono would be nice as i already have an M41. Basic boat fits my pleasure needs.
    So Ill start by getting the hull.
    Now to power it I have the ESC. Now time to shop OSE.
    Can I fit or is it recommended to go 56mm motor on 12S? Which from what ive read I should get about 770kv to have 35000 rpm.
    People have told me to go 10S and a higher kV.
    I also hear the word "prop something" Sorry. I forget the name. But its when you gun it and it creates a phenomenon or air lock type deal. They say they need to "feed" the throttle on. Id like to avoid that.
    Obviously prop choice goes with? An algorithm between weight and capability of the electronics?
    Any help would be appreciated. I know this post is a bit sporadic but my knowledge of boat building is limited. So I have not got the order of things. And have SO many other questions.
    Let's start with. Would any of these make sense or am I approaching this the wrong way and should go back and do a lot of reading?
    Strut http://www.offshoreelectrics.com/pro...prod=ose-80990
    Rudder http://www.offshoreelectrics.com/pro...=ros-spdr-011a
    motor http://www.offshoreelectrics.com/pro...as-060-0054-00
    Mount http://www.offshoreelectrics.com/pro...prod=ose-80927
    Flex cable http://www.offshoreelectrics.com/pro...?prod=ose-150L
    Stuffing tube http://www.offshoreelectrics.com/pro...dh-ks-brass-tb
    Thanks in advance. The three hulls Im looking at
  • NativePaul
    Greased Weasel
    • 2770
    Where do you live? Unfortunately this forum only allows 2 letter locations I don't recognise QC. In USA where most of the members here live their organisations insurance will only cover them up to 10s, In most of Europe including England where I live it is up to 14s, other areas may vary. It may be possible to get third party insurance cover just for yourself, or you may have a private lake and not need it, but it is an issue worth considering.
    Do you want to race or think you may want to race in the future? If so there may be rules to follow that will help you narrow down your setup choices.
    What are your goals for performance and runtime?
    Could you link to the hulls you are thinking of please, you mention 51" and 70" but there is a big difference between the 2, and the MHZ Cougar and Mystic are both about 55".
    Even 55" boats and 400A ESCs are out of my experiance zone so I cant give you any specific advice, but I can give you some generalisations that are true for all boats, or all electrics.
    I would use the highest voltage you can get insured on, that are race legal if you are interested in racing, or you are comfortable with handling in a wet environment, and that your ESC will take, although it is good to leave some headroom on the ESC and not run it at the maximum limits for either voltage or current. The higher the voltage you use the less current you need for a given power so the ESC, wires and connectors will run cooler.
    I think what you have heard of is prop cavitation, all fast boats will have it to some extent coming out of the hole, it does reduce prop efficiency and thrust at low speed. Bigger diameter props with lower pitches will reduce cavitation, and smaller props with higher pitches will increase cavitation. heavier boats have more drag and more inertia, so will have more cavitation for a given prop. There is a compromise to be had between low speed acceleration and high speeds, generally fast boat will accept some cavitation reducing low speed acceleration when the boat is in displacement mode in favour of better acceleration at high speeds. The compromise can goo to far in that you need a certain amount of thrust to climb out of the hole and get up on plane, or you won't ever get to those higher speeds.
    Given props of the same pitch ratio (1.4 is very popular for fast boats) KV matters in that for a given power with low KV you can spin a bigger diameter prop slower with high KV you can spin a smaller prop faster, the Low KV spinning a bigger prop will cavitate less and accelerate better at low speed and may be as fast, but will have more torque roll and paddle wheel effects.
      • 7512
      QC = Quebec..Canada
      • devin120
        • Jan 2017
        • 2
        Yeh.. No rules about cells or anything.
        I'm from quebec canada.
        No plans on racing. I want to go for all out speed runs on a pretty smooth lake. Thus the 16 s. Runtime, 5 mins? Seems fair... Not bashing too hard...
        Thanks so much for the info. Thats alot of the info i needed.
        I shall update on any progress :)
