stock class ques
  • Dr. Jet
    • 1759
    Just get the ballbearing kit for the hardware and call it good for now. The Graupner stuff is not that bad. You don't need to spend a bundle of cash for something that will make a 0.5% difference in overall results. I have a set I plan to use on a similar-sized (29") cat in the future.
    A nation of sheep breeds a government of wolves
    • waynedawg
      • 167
      were di i get the ballbearing kit and what size di i get. also were do i get props for this hardwere?
      • Dr. Jet
        • 1759
        I believe the bearings are 8 mm x 4 mm and are available from bocabearings.com (measure first, they may be 9 mm x 4 mm). Boca Bearings has a huge selection and good service. The bearing kit may also be available here at OSE, and the props are available here as well.
        • waynedawg
          • 167
          metel or fiber props and what is the best kind. sorry for all the ques im have no idea what im doing i was into pattern planes before never did boats
          • waynedawg
            • 167
            what size is the stock shaft for buying props?
            • waynedawg
              • 167
              should i run water cooling for esc and motor?
              • Dr. Jet
                • 1759
                Standard Graupner 4 mm carbon-filled props work with the Graupner hardware. They are relatively inexpensive, require no extensive balancing, and are readily available here. If you switch hardware, you will need to get Octura (or equivalent) metal props for 3/16" shaft. More expensive and sharpening/balancing is mandatory.
                • waynedawg
                  • 167
                  ok found the props what do you think about the water cooling motor and esc
                  • Dr. Jet
                    • 1759
                    It wouldn't hurt.
                    Prop links (Your setup uses 4 mm threaded props):
                    http://www.offshoreelectrics.com/products.php?cat=60
                    http://www.offshoreelectrics.com/products.php?cat=56
                    Good replacement motor:
                    http://www.offshoreelectrics.com/pro...prod=ose-700sc
                    • waynedawg
                      • 167
                      ok all on my wish list just need to find the bearings went to bocca and they wont take mm sizes mabey im just dumb lol
                      • Dr. Jet
                        • 1759
                        Boca does metric, you just have to look for the button to search metric as opposed to inch sizes.
                        http://www.bocabearings.com/main1.as...ksearchbearing
                        • waynedawg
                          • 167
                          wich size is the inner 4?
                          • Eodman
                            • 1285
                            Wayne, I believe there's two meets coming up in Northern NJ .... both in Randolph NJ!
                            location is Randolph Park .... 1 is on Oct 26th - the 2nd is on Nov 9th!
                            You should be able go to www.namba-1.com to confirm!
                            If you can attend one of these you should be able to get a lot of info and more importantly see the speeds they are running at! Both meets are running all electric classes!
                            We did it with a Bang!
                            Cats Are Where It's At!
                            • Dr. Jet
                              • 1759
                              Yes. 4 mm inner, 8 mm outer.
                              • waynedawg
                                • 167
                                ok got the bearings thanks eodman ill try to be there tks
