retrieval system
  • Newboater
    • 359
    Originally posted by martin View Post
    How do you attach it to the tug, is it just a tight fit onto the tugs hull.
    You drive right into it. When you shape the PVC you can make it any width you want.
    • martin
      • 2881
      How do you get the tee fitting onto the u shape tube.
      • ChevyPrerunner
        • Jun 2015
        • 205
        I'd like to know also
          • 4340
          PVC T fittings to not allow continuous lengths of tube to be run through them, they're joints, independent pieces are inserted into each side of the T. Doesn't matter if they're curved or not.
          • Newboater
            • 359
            Exactly
            • ChevyPrerunner
              • Jun 2015
              • 205
              exactly but for some reason I thought that he had bent 1 solid piece of PVC on each end as stated above. Lol confusing now it makes sense. I bought all these supplies for my Atlantic Tug a while ago and will try to put together soon. The Hot Bends make it look better thanks for the tip.
              • Newboater
                • 359
                Sorry should have been more clear. After you make the bends you want you then cut the bend in the center and place in the tee. You do this on both halves and then join the two halves to each other.
                • JJ1TRXSAton
                  • Oct 2016
                  • 88
                  My rescue setup...
                  Going to Hansen Dam for my maiden voyage and didn't want to get stuck out there so made my rescue rig on plans I found on this forum somewhere... rescue tool.jpg
                  James J.
                  • ChevyPrerunner
                    • Jun 2015
                    • 205
                    Awesome looks good
                    • JJ1TRXSAton
                      • Oct 2016
                      • 88
                      Originally posted by ChevyPrerunner View Post
                      Awesome looks good
                      Thanks! Going to test it out tomorrow. Hoping I won't have to use it too often...
                      James J.
                      • SD Eracer
                        • Aug 2014
                        • 262
                        Borrow or rent a kayak. Everything else is questionable method, especially on a river.
