programmingf issues with the seaking 180A on my zonda
  • dbonomi
    • Sep 2016
    • 56
    Hi guys,
    Wonder if you could help me out. When I try to program my seaking 180 esc with the program card all I get on the program card are red lines and no numerical values pop up. These units have a built in bec circuit and the programming instructions seem rather easy to follow but I cannot get the card to program. Can anyone give me specific instructions on what I have to do to get it to work?
    thanks,
    Don
  • martin
    • 2881
    Is this for the Seaking 180a V2 or V3, if its the V3 are you using an extension lead plugged into the 3 prongs sticking up between the motor wires to connect to the prog box.
    • dbonomi
      • Sep 2016
      • 56
      It's the V3. Has 3 prongs. Back of program box has 2 areas for plugs. It gets confusing at that point.
        • 4340
        only one of the programmer sockets has all three pins labeled: negative, positive, signal. Use that one. The other is only marked negative and positive.
        • dbonomi
          • Sep 2016
          • 56
          O.K. What's next? Do I hook up the battery and turn on the Tx. How does the programming card turn on?
            • 4340
            Connect programming card to ESC, leave everything else like normal, connect the battery, programmer should light up with numbers.
            • properchopper
              rcgoatbuild@snotmail.com
              • 7708
              Must be done EXACTLY in that order
              • dbonomi
                • Sep 2016
                • 56
                Thanks! They finally lit up with values and I was able to program it. Yeah! We're off to the races.
