Universal Joint problems
  • DSC1
    • 85
    I have a 6mm to 6mm universal joint that I use in a jet drive boat. The problem is the universal joint keeps coming apart like in the pic. I have it aligned very well to where I believe I could use a straight coupler. Is there any gain to going straight coupler? If you have any suggestions or recommendations I'm open to suggestions. It only seems to be a problem when I'm trying to get full throttle....Which is a big problem to me.
  • grsboats
    • 972
    Honestly I see no gain and no loss with a straight coupler.Years ago I built a mono using a CMB 45 coupled to a jet unit using a Graupner straight coupler with no issues.
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • DSC1
      • 85
      Thanks. Guess I could make one of those myself since they aren't in stock currently. Unless you know some other place that sells them?
      • 785boats
        Wet Track Racing
        • 3169
        I think the problem is that you are most probably spinning that coupler at more revs than it was designed for. About 10,000 or 12,000 i think.
        we used to put a piece of heat shrink over the coupling to stop the pins from flying out when we knew we were exceeding their design limitations. That was with the red nylon ones.
        Here's a couple in my Higgins torpedo boat. I run those 700 series motors on 4s lipo these days.
        But if things are well aligned, a straight coupler might be better.
        • DSC1
          • 85
          Guess I could try that to. Never even thought of trying that! Thanks.
