I recently picked up a 46" Warehouse Hobbies Enforcer from another member here. It had been converted to FE but I didn't buy it with the motor or the ESC. The original owner provided details on what he ran in it, but indicated it was a bit overkill for the hull.
With that said, I started running some numbers with components I am more familiar with (and can afford). I used the FE Boar Calculator at http://www.radiocontrolinfo.com/rci-fe-boat-calc/ and came up with the following (I was targeting mid-40 MPH, low current, high voltage (8S2P - 4, 5000mah 4S packs - a pair each wired in parallel (to get 10,000mah) and then those pairs wired in series (to get 29.6v)) components...
I'm looking for thoughts on this combination as well as if there might be better combinations that say produce longer run times, lower current, increase speed (just a bit), etc. The boat already has a surface drive, trim tabs, turn fins, stuffing tub, 1/4 scale servo, rudder, and water pickups.
Thank you for your time.
