Genesis single vs twin
  • Kram
    • Aug 2016
    • 48
    Hi!
    I bought a genesis hull but i wonder if i should go for twin motors og single?
    Is there any advantages using dual setup?
    Do the boat run better with dual or what?
    Thanks for all help!
  • littlepooper206
    • Jul 2014
    • 159
    Well my question first is... for you what i the MPH goal for that boat ?
    Then second question will be an it doesn't have to be on the dot or anything just a ballpark number will do just fine. but amount of cash do you have to build/play with lol.... and with those two informed for the forum to see then you will start getting help from people
      • 7277
      Twin motors=double the cost/headaches.
      If this is you first FE, then go single.
      • dmitry100
        • Mar 2015
        • 1264
        But wouldn't that technically mean double the heat for the hardware/electronics seeing how you would need bigger everything to even come close to a dual?
        • Kram
          • Aug 2016
          • 48
          Much speed to gain on dual?
          Like.. If i choose 2 Leo 4082 and 2 T180A Vs 1 4082 and 1 T180? Same props
          I find that setup quit expensive... Do anyone knows any cheaper motors?
          • Kram
            • Aug 2016
            • 48
            Not my first boat!
              • 7277
              Leo 4082"s would be a tight fit in each sponson.
              • TRUCKPULL
                • 2971
                Hello Kristian
                I run a Dual Mean Machine Cat
                This is my budget setup, and it works.
                2 -Leopard - 3674 -2200KV
                2 - OSE - Raider 150A ESC's
                2 - Giant Power 4S - 5000mAmp- 4S2P setup- ESC's are wired so they each see 4S2P
                Props are a pair of ABC 1615-17/45 left & right
                Speed - 100K
                Turns like on rails.
                For more speed try a pair of ABC- 1616-17/45
                Larry
