ProMarine MTR Flex shaft cable unwinding
  • Norgan
    • Jun 2016
    • 2
    Long story short - Had the original flex cable that came unwound so I got a replacement from ProMarine. Unfortunately that came unwound as well after only a months time. Does anyone happen to know the size of the flex cable and if there is a direct replacement on the OSE store? I'm looking to try a different brand as I've become a little frustrated with having 2 cables fail within a 3 months time. Thank you.
  • JimClark
    • 5913
    Can't you measure it?
    Sent from my SM-G900T using Tapatalk
    Billy Graham
      • 7512
      Is Promarine using reverse wound cables by mistake???
      • RayR
        @SiestaKey.calm
        • 1591
        It is a .187 cable (just measured one last week). You will have to cut it to length.
        • jwohlt
          • Nov 2015
          • 41
          Go with a 078 wire drive. PM me and I can fix you up with either. I actually think it is a 4mm cable since it is china but I could be wrong. The shaft is a different length than std 2.25" Our cable is better than china cable also.
          • Flanders
            • Jun 2016
            • 16
            Dont use reverse it is still on in the esc on his rtr boats
            • Steven Vaccaro
              Administrator
              • 8932
              Most esc's wont run full throttle in reverse. You should be able to run a flex cable in reverse at slow speeds. Try Jeffs wire drives or if you want a .187 cable of good quality, let me know?
              Steven Vaccaro
