OSE 6mm Plugs - Help
  • TRUCKPULL
    • 2971
    I have some
    Product ID: ose-qs6p plugs
    Does anyone know how to take these apart without ruining the plastic plug??
    Larry
  • bozo586
    • Aug 2009
    • 344
    larry--i believe you just push them out toward the wires! they just snap together after you solder the bullets to the wire
    • covedweller
      • Jul 2014
      • 69
      Usually I cut them off with wire cutters. It is hard enough to assemble them, disassembly would be too much work for me. Buy em in bulk. Have had very good performance with these connectors on everything, esc, motor, batts.
      • Tamelesstgr
        • Jun 2014
        • 1512
        maybe try warming them up some with a heat gun, that usually helps me when soldering 4mm banana plugs for charger leads.
        NEVER SATISFIED RACING
        Fine Design 32 V-Hull 4082+6s
        • Pennstater
          • Sep 2015
          • 70
          This is a month old thread but I'll chime in anyway. I use XT150 connectors and I recently had to remove them from some Lipo's that went belly up. I heated the plastic with a common hair dryer for about a minute, then used a little muscle to push them back towards the wire (towards the pack) - they popped right off. I then unsoldered the actual bullet connector and snipped off the exposed wire. I did this one at a time to avoid the possibility of shorting.
