Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Recoil 26 - RcBoaters Forum
Recoil 26
  • vincea
    • Sep 2015
    • 91
    Recoil 26
    Anyone have one.
    Like?
    Dislikes?
    Improvements meeded?
    Sent from my SM-G920V using Tapatalk
  • Boardin
    • Jun 2016
    • 1
    Just received mine from HH. Gonna run it this weekend. Will follow up. Have heard nothing but possessive though.
    • Mitch S
      • Jan 2016
      • 47
      I have had mine since January, great boat, fun to run.
      Turn Fins need upgrading.
      Do a search and you will find much more information.
      • Darin Jordan
        • 9446
        Yup... Here's how I did mine.
        Something like these would work well, and won't break the bank:
        http://www.offshoreelectrics.com/pro...prod=ose-80049
        Darin E. Jordan - Renton, WA
        • vincea
          • Sep 2015
          • 91
          Picked one up.
          Runs like on rails
          • truckone176
            • 6
            I just ran mine for the first time last weekend and had big problems and would like some help. Ian new to the rc boating hobby and learning quite a bit. The boat kept getting quite a bit of water in the hull and I could only run for about 30 to 40 seconds before it would act up and stop responding to the controls. The boat was within 70 feet of my pontoon boat when this happens. Also, there were a couple of times that it would take off on its own and then stop. Does anyone have any suggestions?
            • Heath M
              • Mar 2008
              • 865
              You need to work out how the water is getting in and stop it. Water and electrics don't mix which is why the boat is acting on its own. You may have damaged the receiver which may now need to be replaced.
              Brisbane,QLD, Aussie
              • truckone176
                • 6
                Thanks, I think the only place that the water is coming in is the drive tube.
                  You have two threads on this boat running at the same time, you will get more help with just one.
                  Have you submerged the boat in the bath tub to find out where the water is coming in? Just set in water for a few minutes with the hatch off to see if it leaks? It is no wonder the boat stops working if it is full of water...
                  • vincea
                    • Sep 2015
                    • 91
                    Running the chit out of ours.
                    Canopy is cheap crap...
                    1 motormounts broken free from hull.
                    I'm gonna go thru them and strengthen canopies with cloth.
                    Might even vaccum firm my own.
                    Since not available. Backordered
                    • vincea
                      • Sep 2015
                      • 91
                      Motor mount broke now.
                      My 7 yr old is bummed.
                      • stony30
                        • Aug 2011
                        • 36
                        How did your mount break ?
                        • vincea
                          • Sep 2015
                          • 91
                          Just did??????
                          • stony30
                            • Aug 2011
                            • 36
                            Did it happen after a flip or anything ? It just broke ?
