supervee 27 overhaul?
  • fullthrotteljunkie85
    • May 2016
    • 39
    hello
    so i have the supervee 27 and I think its got the 1750kv blue motor stock well I have had for about month or so and enjoyed all the moments but the esc went bad and I have been using 2-2s lipos 5000mah 40c and that helped alot with a 42-55 grim racer 2 blade prop for speed but never recorded the mph. Anyways after esc went I ordered a hobbywing seaking 120amp esc but Im wondering what motor yall suggest that would be faster then mine on 4s and would be insane on 5/6s if I ever could make it stable enough to do so. Im not sure if I need to go with higher kv large length can size or what? If I could do 50mph I think id be happy. Any suggestions on motor that someone has maybe used before that was greatly approved over the stock blue 1750kv?
    Thanks
  • Tamelesstgr
    • Jun 2014
    • 1512
    I have a similar sized boat with my Shockwave 26. Over the winter I switched to the Aquacraft 2030KV motor that is in the UL-1. I am running 4s and a Turnigy 120 amp esc. I started with a 40mm plastic propeller and was happy with the speed over the 1500KV motor I had previously. I have been data logging this setup, and so far have seen a max amp rating of 86 amps. That's the reason I chose the 120 amp version, I am running about 30,000 rpms under load which is a good all around range. 5-6s might be a handful on that Supervee Hull, but I have seen youtube videos of it being done.
    Here is my build log, page 2 starts the current setup:
    http://forums.offshoreelectrics.com/...r-Improvements
    Video of the 40mm prop:
    I haven't GPS recorded the speed, I would say low to mid 30's, but I have many props to sharpen and test this summer.
    Ken
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • Tamelesstgr
      • Jun 2014
      • 1512
      This was the previous 1500kv motor on 4s, probably a 42-45mm plastic prop as well.
        • May 2016
        • 39
        thanks for reply ,so do u think the 2030kv would be big improvement over my stock 1750kv in my supervee 27 non r? I did order the seaking 120amp so maybe ill try 5s on my stock motor if it will handle it. If i had the money id just do a different boat but I like the boat, just needs adjustable trim tabs and maybe anouther turnfin on other side. If i could do about 50mph id be happy. Im worried if I did go big motor for 5 or even crazy for this boat 6s it wouldnt ever be able to run flatout
        • Tamelesstgr
          • Jun 2014
          • 1512
          Couple questions, is the 42x55 prop sharpened and balanced? Why did the stock ESC fail?
          If money is a concern, don't worry about running 5s and 6s, concentrate first on getting the boat dialed in and picking a motor that will work with the ESC.
          My uncle has a Supervee 27, and we did add the port side turn fin, that helped a lot.
          In my opinion his rudder water cooling setup doesn't flow much water. I much prefer two cooling pickups, one for ESC and one for the motor.
          There are a lot of good threads on this boat:
          27
          http://forums.offshoreelectrics.com/...shless-Q-amp-A
          27R
          If you are chasing speed I might invest in an inlay to strengthen the hull, a tumble at 50 could send you to the bottom real quick.
          • Tamelesstgr
            • Jun 2014
            • 1512
            4S Setup with the 2030KV motor and 120 amp ESC
              • May 2016
              • 39
              so not sure what made esc burn up but i did get the seaking 120amp and ordered a dynamite 2200kv so even on 4s it should be more speed. Thats quick boat u did video . Hope those dynamite motors are okay cause Ive always used cordova motors,
              neu motors from steve neu and poseidon rc motors for my rc cars for speed runs. Only dynamite I had was stock in my sons losi xxl2e monster truck
              • runzwithsizorz
                • Jan 2009
                • 901
                I would not hope for, or even shoot for 50mph with this hull. Even with the water like glass, this small shallow vee hull gets fidgety above 40mph. I have the first edition SV, and I too lost the ESC.
                Replaced it with the same amp ProBoat ESC, and swapped the motor with an AMMO 2300kv, it was fast but too unpredictable to be fun.
