Travis I always run riggers and can tell you that using a knife rudder on my saw nitro and FE boats there is significant difference in speed....I'm curious to see in your boats too .Gill
Water pickup drag testing
Originally posted by grsboats View PostTravis I always run riggers and can tell you that using a knife rudder on my saw nitro and FE boats there is significant difference in speed....I'm curious to see in your boats too .Gill
Let me give you a nice laugh. 100. Mph. Saw. Boat. Rudder. Lmao
Look how long
So if. you want to make a good test try a knife rudder in this catGO FAST AND TURN RIGHT !
www.grsboats.com.br
Scared to. It's dialed in nicely and if I decrease rudder drag it's likely going to blow over.Originally posted by grsboats View PostSo if. you want to make a good test try a knife rudder in this cat32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Some of the guys up here in the great white north think out side the box .... well several boxes ! JB weld/epoxy brass tubing down the back of the rudder( clean and ruff both surfaces) with just a hair past the bottom of the rudder or less. worked very well for Marc Andre's p-hydro
Cheers, Jay.
I use a mini brushless water pump with a remote switch from 3 channel and it weights almost nothing...
I bought it from ebay and i've tested up to 18 volts!!!!!!
Even when the boat is stoped it cools down everything...
Originally posted by Nikolas Andriop View PostI use a mini brushless water pump with a remote switch from 3 channel and it weights almost nothing...
[ATTACH=CONFIG]143625[/ATTACH]
Anyway you provided me a link to this pump?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
How sexy would that be! Use a coupe of these...Originally posted by kfxguy View PostHoly damnit. That's a good idea. Thanks for that! I've seen the gundert ones but I like this much better. My builds are now going to change a bit. I guarantee that's the least drag setup there.
http://www.offshoreelectrics.com/pro...prod=ose-80400Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
I wonder if the pump is this one. I'm interested
http://www.ebay.com/itm/DC12V-2L-min...YAAOSwNsdXSAk~
Dan o, I have some of those fittings and they are huge. Like 1/4 Id hose fits on the nipple. Lol32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Found this. Pretty sweet.
Noisy person
This is a "diaphragm" based pump... pretty fast if you give it enough voltage (12v+). Its sort of a heavy duty. I'll update with the weight of this thing.
http://www.ebay.com/itm/R385-Aquariu...kAAOSwnGJWTLNg
I also have this one, it was cheap but this is the most common type of pump out there-- the Gear based pump. Doesn't really like much voltage... motor gets kind of hot at 12v.
http://www.ebay.com/sch/i.html?_odkw...+Pump&_sacat=0
Most commonly seen used in SAW cat builds from MBP-RC (It is also gear based). It's 28 euros... oddly expensive for some reason:
These might be fun to experiment with for the price.
http://www.ebay.com/itm/10pcs-Mini-W...0AAOSwpdpVYax8Noisy person
