Spektrum rx's going for a bath
  • Steven Vaccaro
    Administrator
    • 8724
    Each of my esc's gets a corrosion X bath before use. This makes a huge difference in keeping equipment working.
    Sent from my SM-N910V using Tapatalk
    Steven Vaccaro
  • Steven Vaccaro
    Administrator
    • 8724
    After the bath, I let them drip dry and then clean the back with alcohol to prep the surface for Velcro.
    Steven Vaccaro
    • zooma
      Local club FE racer
      • May 2014
      • 652
      Absolutely, Steve. And, I've been doing that for years with my seaplane receivers and ESCs, because they get wet a lot.
      Ron - The Villages, FL
      • JimClark
        • 5902
        Is that good for the newer DSMR receivers also?
        Sent from my SM-G900T using Tapatalk
        Billy Graham
        • Steven Vaccaro
          Administrator
          • 8724
          I don't see why not Jim.
          Steven Vaccaro
          • JimClark
            • 5902
            I just dont know much about the coating they use on the newer recievers (Reliakote waterproof coating)
            Billy Graham
            • jantagg
              • 187
              What is a better than Crorrosion X is a product called LIQUIGUARD. It will waterproof any electrical device. I have filled up a glass of water and placed a receiver in it overnight and it worked just fine the following day. It sprays on as a clear liquid, when dry leaves no film.
              • runzwithsizorz
                • Jan 2009
                • 856
                Looks pretty good, but yikes! not cheap. $30 + shipping for 8oz.
                  • 7990
                  Looks pretty good, but yikes! not cheap. $30 + shipping for 8oz....
                  True, but what do a couple of receivers cost? Since so many boaters seem unable to waterproof their boats, that seems like cheap insurance to me.
                  • JimClark
                    • 5902
                    Jay do you know anything about the "Reliakote" Spektrum is using? Will it react with either corrosion x or this liquiguard?
                    Billy Graham
                      • 7990
                      Nope. I am assuming it is a decent product, and none of my SR receivers are sprayed with CorrosionX. I used to spray all my receivers and ESCs with it, until I discovered that it loosened the adhesive Castle uses in their ESCs to hold the metallic "cooling plate" under the control board. When that happens the plate can rotate and cause a direct short - poof! Only happened once but that was enough. I now use CorrosionX in limited quantities. It is still a great produce IMO.
                      • Flying Scotsman
                        Fast Electric Adict!
                        • 5190
                        FYI: Jim
                        AndyKunz (Spectrum Development Team) cautioned me on a previous thread on those DSMR receivers ....he stated he did not recommend Corrosion X as it causes plastic to become brittle.
                        Douggie
                        • Steven Vaccaro
                          Administrator
                          • 8724
                          people including myself have been using Corrosion x for years without issue. When we first started using it, it was on servos. because none of them were waterproof. I still have servos that are plastic and still work fine.
                          Steven Vaccaro
                          • T.S.Davis
                            • 6228
                            I've been using this stuff for 10 years for various things. I don'tknow if it has the same problems Andy once described. Back in the FM days I used it constantly.
                            Noisy person
                            • SD Eracer
                              • Aug 2014
                              • 262
                              We primarily run in salt water here in San Diego, if it wasn't for CorrosionX, I honestly don't think we could do our hobby. Or it would be a whole lot more expensive at the least.
                              For my receivers, I just pop them out of their plastic cases, and spray the rx boards directly. I let it sit for a minute or two on a paper towel, and then put it back together.
                              I've had similar treated receivers completely under ocean water for over 30 minutes and still function afterwards. Just wash in fresh water, and respray with CorrosionX.
                              For my brushless motors if they get flooded, I simply wash them in fresh water under the sink, shake off excess water, and spray the insides with CorrosionX. Let it drain out, wipe off and reinstall.
                              Funny, I learned about CorrosionX after reading my Aquacraft Lucas Oil manual, where Grimracer states that if your motor gets wet, pickle the inside of the motor with either WD-40 or CorrosionX. If he happens in freshwater, I use WD-40 to save money, but anytime salt touches a motor, its always CorrosionX.
