What prop size for 2 AQ 2030 powered boats?
  • Andris Golts
    • 506
    Hi all finally finished a tunnel and a rigger. Now that i have discovered using to small a prop can cause the same damage as one to big i need input. The first boat is a JAE .21 FE AQ 2030 motor 120 amp esc Giant power 4s 5000 mah 65 c lipo .What min dia prop ? What max dia prop ? Second hull is a Dunlap outboard wood over foam tunnelhull 30'' in length AQ 2030 motor 120 amp esc Giant power 4s 5000 mah 65 c lipo .What min dia prop? What max dia prop ? Regards Andris Golts.
  • grsboats
    • 972
    For the Jae you can go with 1450 (46mm) or H-5 and H 7. Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • HTVboats
      • Jun 2011
      • 802
      On the tunnel side the AQ 2030 and a 42X55 Grim Racer prop is a perfect match. An M445 with a reduced diameter seems to be the heat racing choice. Safer to go with the 42X55 for sport running as the M445 can kill your electronics if your not careful.
      Mic
      Mic Halbrehder
      IMPBA 8656
      NAMBA 1414
