UL-1 Guts, want to transplant to a V-Hull... any suggestions?
  • cptcrusty1
    • Feb 2011
    • 26
    I have a UL-1 Superior that's been sitting for a while. I was never happy with only turning left and hung it up. I'd like to do some transplant surgery and put it's guts and running gear into a V-hull.
    Would anyone know specifics like size, maybe some models, etc?
    I have seen the UL-1 setup run in a lightweight Titan 29 very successfully, but the Kv is on the high side for a sport boat that size. The Titan works because it has huge lift to reduce drag. A slightly smaller, light boat would probably work better for you.
    • Tamelesstgr
      • Jun 2014
      • 1512
      I recently transplanted the UL-1 motor into my son's Shockwave 26 v-hull.
      AQ2030KV on 4s
      Upgraded .187 flex shaft, no teflon liner
      Turnigy 120amp esc (want headroom to try aggressive props)
      Build Log:
      Page 2, Post #52 is where the current setup is
      http://forums.offshoreelectrics.com/...ovements/page2
      Video:
      NEVER SATISFIED RACING
      Fine Design 32 V-Hull 4082+6s
        • 7512
        Find a AQ Revolt hull...perfect match.
        • Tamelesstgr
          • Jun 2014
          • 1512
          You could also do an Aquacraft catamaran hull and turn left and right.
          • SD Eracer
            • Aug 2014
            • 262
            The UL-1s 2030kv motor works great in a Revolt 30 or Lucas Oil.
            Just be careful, because with the Lucas Oil for example, it turns an otherwise 45 mph boat a solid 50+ mph boat. Which is just about too much for that hull to handle a hard flip or crash.
            My Lucas, which was clocked at 42 mph when stock with the plastic prop and 1800kv motor, went up to 52 mph with the 2030kv UL-1 motor and an Octura X642 prop. Not bad for a RTR boat running on 4S.
            I suspect the Revolt 30 mono would be around 47-50 mph with a 2030kv motor and decent brass prop. Plus its much easier to repair and reinforce than the Lucas double tub hull design.
            Want a fast mono? Get a TFL Pursuit, a SSS 4082 2000kv motor, OSC .187 flexshaft, Turnigy 180a ESC, Octura X642 prop. Do some basic hull reinforcements with carbon or additional fiberglass cloth, and you will have a solid 70mph mono for less than $450 all in.
            Though I digress, you wanted to use the motor and ESC from your UL-1. How about taking off the turn fin? Have you tried running it without that fin?
