Installing stuffing box in J.A.E .21 FE ?
  • Andris Golts
    • 506
    Hi all ready to install brass stuffing box on my J.A.E .21 FE rigger im using .150'' flex cable with no teflon liner instructions call for 1/4 '' brass tubing.
    Would 1/4'' brass not be to large a diameter for .150 cable? Regards Andris Golts.
  • Doug Smock
    • 5264
    Yes sir. 7/32 is what you want to use.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • grsboats
      • 972
      Hi Andris just a question..why use .150 cable?I would recommend to use .187 with 1/4 stuffing box...this is what I've been doing to my customers boats!BTW what is your set up?Thanks Gill
      GO FAST AND TURN RIGHT !
      www.grsboats.com.br
      • longballlumber
        • 3119
        When you guys are building with 7/32" stuffing tube how are you managing the strut/stub end. The JAE Strut is pre-drilled for a 1/4 stuffing tube.
        • grsboats
          • 972
          You will have to solder a 1/4 piece of brass tube with 7/32 ID to your 7/32 stuff to work as a sleeve to fit correctly the strut....150 flexshafts are more suitable for the .12 Jae's not for the .21/Fe ones.
          www.grsboats.com.br
          • Andris Golts
            • 506
            Thahks to all for the excellent information . Regards Andris Golts.
            • Doug Smock
              • 5264
              You'll be fine with the .150 if you plan on running a P Limited set up or similar. If not, I'd do as Gill suggested and go with the .187.
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • longballlumber
                • 3119
                That's what I figured. Just wanted to make sure you didn't have any new tricks up your sleeve.
