How often do you grease the flexshaft?
  • Tony
    • 420
    After every run, or once in awhile?
  • Bill-SOCAL
    • 1409
    After each day of running, or if running a lot sometimes during the day. I re-grease after every run in saltwater.
    At the end of each day I pull the shaft, clean it, spray with CorrosionX and store hanging vertically. I re-grease and put it back in just before heading out to the lake.
    Don't get me started
    • tylerm
      • 310
      Our clubs pond is filled up with water from the harbour, so it is sometimes quite salty. I personally use grimracer speedgrease and just grease the flex in the morning and it is sweet for the day. If your using oil or something like that you might have to re-grease more often. I find its not the flex that looses the lube its the stubb shaft. Of course pull your shaft at the end of the day and give everything a good cleanup.
      Tyler.
      • Avanti
        • 1298
        usually before the day of running starts I grease it up,
        should be cleaned and regreased when your done too.
        The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
        • oldshovelhead
          • 33
          I service the drive as part of my post-run maintenance which is done of course, after every run.
          • Diegoboy
            • Mar 2007
            • 7444
            ...i guess the answer "every time too much water gets in through the drive line" would be wrong?
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              I try to grease my shaft after every wank
              Douggie
              • Eyekandyboats
                • 1935
                every time i put the drive shaft in the boat..
                i take my shafts out of the boat after a day of racing. so i grease once a race. and for one boat a day consists of about 3 runs and maybe a couple test runs.
                and then i pull it out, dry it off and oil it and store it till next time
                EYEKANDYGRAPHICS
                www.rclipos.com
                • ReddyWatts
                  • 1756
                  Douggie
                  How long since your last wank Douggie?
                  ReddyWatts fleet photo
                  • Chop
                    • 522
                    There is a fine line between "hobby" and "mental illness."
                    • Spot Me 2
                      • 770
                      Please don't answer!! We don't want to know
                      MMGMMarine
                      RobertsonRacing
                      • Jimmy Sterling
                        • Apr 2008
                        • 417
                        Why does a flex shaft need to be stored vertically ?
                        Jimmy
                        Come to the FASST side
                        • SJFE
                          • 4867
                          HAHAHAHAHA He said Wank.
                            Less likely to pick up grit, lint, etc. I usually store mine in my clean toolbox or in the boat hull itself for the same reason.
                            • Jimmy Sterling
                              • Apr 2008
                              • 417
                              So a flex does'nt really need to be stored vertically so long as it stays clean
