I have heard that these both have the same hull, but different decking. Is there any reason to choose one over the other when shopping for the bare hull?
Pursuit or DF Cyberstorm 33
Tags: None
So, no responses yet. Maybe if I ask the question this way:
What is the best hull for P class oval racing? I have seen the NAMBA FE results, seems to be a mix of Cyberstorm and Pursuit.
Cyberstorm has a deeper vee and different top. Pursuit has same vee as Cyberstorm however Cyberstorm is built a bit better. Df hulls are built well.
I built both of them at the same time. The Cyberstorm for me & the Pursuit for fellow club member Pete. We raced against each other many times. Results were pretty even.
But I agree with Ray. The Deltaforce boats are a much better built boat. A bit more solid & sharper edges.
I recently sold the Cyberstorm to Pete, so he has them both now.
http://forums.offshoreelectrics.com/...uit&highlight=See the danger. THEN DO IT ANYWAY!!!
I hate the way the front of the pursuit hatch attaches to the deck with the molded extension that slips into a slit. Does the DF version attach the same way? I would much rather use screws all the way around personally since it will set down on a foam seal much better.
No. There is no tongue on the Cyberstorm hatch.See the danger. THEN DO IT ANYWAY!!!
